Signal for initial test of FIR filter
atferrari
Most Helpful Member
I completed the simulation of a FIR filter algorithm and I will try it in a 18F micro, for the moment only with a 4-MHz xtal.
PLease note that I have no previous experience in these filters.
I intend to test it using: sinusoidal 280 Hz (4V pk-pk) plus sinusoidal 2500 Hz (0.5 V pk pk) plus noise (appr. 300 mV pk-pk). All that coming from a summing amplifier which I just soldered and runs OK.
I am about to calculate the antialising filter. For the moment sampling rate would be 2300 Hz.
My questions:
Since I intend to recover, obviously, the 280 Hz, is the signal above a valid one for a first test?
I am aware of the reccomended tests where the filter taps are set only to 1 or 0 on purpose. Would you suggest something else?
Gracias for any help.
