shift register needed
AtomSoft
Im looking for a Shift Register with a Latch and Serial Data Out.
More info:
Serial in 8 Bit Parallel Out with Latch and Serial Out for daisy chaining.
More info:
hi atom,
This S/R is OK for driving devices.
Good luck with the job.
Nice! quick too! thanks!
Can i bother for 1 more thing ? lol
I need a cheap fast NPN transistor. Not sure if its called a MOSFET? i know nothing of types lol
switching at least 100-200mA
What frequency and voltage are you switching at? A BFY51 has an Ft of around 50MHz....is that fast enough for you...?
A BF471 has a higher Ft and is a high voltage device
lol im going to use a 8-20MHZ pic.... 50 should be great lol might overkill but i need something that can switch as fast as i can on a pic of that speed.
I found this:
74HCT4094N
At NEWARK.. i kept look based on info from the first one Eric posted and found it....Thanks!
Transistor i will look into now thanks
Those are SOIC only i think... i found the same in DIP
TPIC6A595
Are wanting a 'wire thru' lead transistor.?
If yes, the 2N2222 is a good general purpose npn.
thanks ill make sure to get the FAIRCHILD ersion: PN2222A since it can handle 1A and is cheap
hi atom,
Watch out for the 3 different case styles for the thru pin version of the 2N2222:)
