Hi All
I wanting to write a program that will flash 2 LEDs on to seperate output pins, that I can manage. But now what I'm wanting to achieve is, writing several different patterns and using a input pin as a switch to change between the patterns, and if possible, for it to remember which pattern it was on when power disconnected (unit turned off) so when its powered up again it will automatically go back to that pattern.
I'm using SciTE4gcBasic to write the program and then compile it to a .ASM and .HEX files.
what I need to figure out:
- Does each pattern needs to be writen into its own "SUB PatternX"?
- How do I make it run repeatedly on that Sub until input activated high?
- Require an "interupt" on the input pin to count through the patterns???
- How to store which pattern it was running into memory when power removed?
Thanks in advace!
#chip 16f628, 4
#config INTRC_OSC
#define LED1 PortB.0
#define LED2 PortB.1
#define SW1 PortB.2
dir LED1 out
dir LED2 out
dir SW1 in
Main:
~~~make start up on last used pattern?
~~~interupt from SW1
goto Main
sub Pattern1
[COLOR="Red"]Pattern code[/COLOR]
end sub
sub pattern2
End sub
sub pattern3
End sub
sub pattern4
End sub
goto Main
Thanks in advace!
