Hi everyone,
I am trying to send a text message via a Wavecom fastrack supreme and a 16f628
I know that the subject has been covered many times before, but I can't find much written in .ASM.
I need some help regarding the response from the modem.
When I connect the modem to the PC and send AT+CMGS="***********" <ENTER> (number to dial), I receive a response from the modem,(>).
The question is this... do I need to look for 0x3E before I can send the message?
I haven't a max232 at the moment, so I haven't yet tried to send the pic to the PC.
Thanks in advance for any help received.
list P=16F628
#include <P16F628.INC>
ERRORLEVEL 0, -302 ;suppress bank selection messages
__config 0x0210
cblock 0x20 ;start of general purpose registers
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
Xmit_Byte ;holds byte to xmit
Rcv_Byte ;holds received byte
Bit_Cntr ;bit counter for RS232
Delay_Count ;delay loop counter
endc
SER_PORT Equ PORTB
SER_TRIS Equ TRISB
SER_IN Equ 0x07
SER_OUT Equ 0x06
org 0x0000
Start movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
Initialise clrf count
clrf PORTA
clrf PORTB
call SER_INIT ;initialise serial port
call Long_Delay
movlw 0x19 ;9600 baud with 4Mhz Internal Oscillator
movwf SPBRG
movlw 0x00 ;select first string
call Print_String
;Done goto Done ;loop for ever
Print_String movwf count1 ;save string number (0 is first string)
clrf count ;set counter register to zero
NextLine movf count1, w
xorlw 0x00 ;is it a zero?
btfsc STATUS, Z
goto NextChar ;if so we've reached required string
movlw 0x07
movwf PCLATH
movf count, w ;put counter value in W
call Dial_num ;get a character from the text table
clrf PCLATH
btfsc STATUS, Z
decf count1, f
incf count, f
goto NextLine
NextChar ;display selected string
movlw 0x07 ;set PCLATH for strings in last page of memory
movwf PCLATH
clrf PCLATH ;reset PCLATH
btfsc STATUS, Z
return ;exit from routine
call XMIT_RS232
incf count, f
goto NextChar
;Serial routines
SER_INIT
BSF STATUS, RP0 ;select bank 1
BCF SER_TRIS, SER_OUT ;set B6 as an output
BSF SER_TRIS, SER_IN ;set B7 as an input
BCF STATUS, RP0 ;select bank 0
BSF SER_PORT, SER_OUT ;set SER_OUT high
RETURN
XMIT_RS232 MOVWF Xmit_Byte ;move W to Xmit_Byte
MOVLW 0x08 ;set 8 bits out
MOVWF Bit_Cntr
BCF SER_PORT, SER_OUT
CALL Bit_Delay
Ser_Loop RRF Xmit_Byte , f ;send one bit
BTFSS STATUS , C
BTFSC STATUS , C
CALL Bit_Delay
DECFSZ Bit_Cntr , f ;test if all done
GOTO Ser_Loop
CALL Bit_Delay
RETURN
Rcv_RS232 BTFSC SER_PORT, SER_IN ;wait for start bit
GOTO Rcv_RS232
CALL Start_Delay ;do half bit time delay
BTFSC SER_PORT, SER_IN ;check still in start bit
GOTO Rcv_RS232
MOVLW 0x08 ;set up to read 8 bits
MOVWF Bit_Cntr
CLRF Rcv_Byte
Next_RcvBit CALL Bit_Delay
BTFSS SER_PORT, SER_IN
BCF STATUS , C
BSF STATUS , C
RRF Rcv_Byte , f
GOTO Next_RcvBit
CALL Bit_Delay
MOVF Rcv_Byte, W
RETURN
Start_Delay MOVLW 0x0C
MOVWF Delay_Count
Start_Wait NOP
DECFSZ Delay_Count , f
GOTO Start_Wait
RETURN
Bit_Delay MOVLW 0x18
MOVWF Delay_Count
Bit_Wait NOP
GOTO Bit_Wait
RETURN
;End of serial routines
;Delay routines
Long_Delay
call Delay255
call Delay255
call Delay255
call Delay255
return
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay10 movlw d'10' ;delay 10mS
goto d0
Delay1 movlw d'1' ;delay 1mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0 decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
;end of Delay routines
org 0x0700 ;set to last page of memory
Dial_num addwf PCL , f
retlw 0x61 ;A
retlw 0x54 ;T
retlw 0x2B ;+
retlw 0x43 ;C
retlw 0x4D ;M
retlw 0x47 ;G
retlw 0x53 ;S
retlw 0x3D ;=
retlw 0x22 ;"
retlw 0x30 ;0
retlw 0x37 ;7
retlw 0x37 ;7
retlw 0x38 ;8
retlw 0x33 ;3
retlw 0x37 ;7
retlw 0x31 ;1
retlw 0x32 ;2
retlw 0x35 ;5
retlw 0x31 ;1
retlw 0x39 ;9
retlw 0x22 ;"
retlw 0x0D ;ENTER
end
