Selecting and driving a P Channel MOSFET
Macka
I'm wanting to drive some LEDs in an 8x32 LED matrix. The LED characteristics are:
If = 20mA
Vf = 3.4V
Vcc = 5V
I'm planning to arrange the LEDs in common anode configuration and will drive the low side with TPIC6B595Ns (high current 8-bit shift register). If a full row was ever on, it'd pull a current of 640mA.
My understanding is that if I use a logic level P channel MOSFET, I need to pull the gate low to activate it.
I was thinking I could use one of the TPIC6B595Ns (since I need a shift register anyway) to drive the gate. eg putting a 1 into the the LSB of a TPIC6B595N would pull the output low and hence turn on the MOSFET.
I've looked around on the AU element14 website and I selected a IRFD9120PBF MOSFET, because it has a Gate-Source threshold voltage of -4V (max) and a continuous current rating of 1A.
So, my questions are:
1) Can I drive the MOSFET like this?
2) Will this MOSFET do the job? - If not, why? and how do I go about selecting the correct MOSFET for the job?
Since the shift reg is open-drain, there is no pull-up, so you will have to add one.
ok, so other than the need for a pull up, say 1kΩ, everything checks out?
Thanks guys
