Salvaging parts from a UPS
axro
I have a huge UPS that I want to extract some salvage parts. How can I safely discharge the monster caps that are in it so I don't kill myself.
i never opened a UPS, but i guess must have a pair of huge capacitors for filtering and storing the power. To discharge them connect them with 10Ohm >10W resistor and will do the job....That's an idea to proceed
Factory built devices have to have a way that they will automatically discharge the capacitors in the system so I wouldn't worry about it too much. If its been turned off and unplugged with the battery removed for more than 15 minutes you are safe.
oh thnx....pity i had one some years ago and i give it for recycling....
Before you canibalize it for parts, have you tested hooking good batteries to it ?
That is mostly what fails in UPSs. And you would be disabling what many people is after, a huge DC to AC inverter. :( I use one in my car for 115VAC on board.:)
I'm not sure how much good this would do since it runs off 24V(2 12V batteries in series). Would there be any uses for that?
Yes, many biggie UPSs run on 24V.
Still good for non automotive uses; as inverter for solar panels charging 24VDC systems.
Inverters building and uses are the most sought after projects in forums. ;)
Are the huge things(a few pounds) that look like transformers, are they linear transformers, switching transformers or inverters?
They are likely the main power transformers that step up the lower voltage up to the higher line voltage. They will have the primary's as the low voltage and the secondaries as the high voltage. But typically you can reverse them if needed to make a linear power supply out of them. and being UPS transformers they will have a high surge capacity.
However most UPS units have smaller transformers than they are rated for output wise. Their duty cycle is limited by the battery capacity so they dont need to be continuously rated at their maximum capacity. Many can only hold their maximum rated outputs for a few minutes and typically can only do about half there maximum rating as continuous duty units.
Also if used as step down transformers their outputs will be much lower than what the DC drive voltage was. Being a 24 V system they will likely only have about half that as an AC output. To maintain the steady line voltage as a backup power supply the use a sort of PWM method to keep the line voltage constant even though the battery voltages drop off rather fast.
Their windings ratios typically are closer to being what the battery's lowest working voltage is and then having that stepped up to the peak voltage of the output wave form. Hence the lower output voltage when used as a step down transformer.
Got a picture available. It would help with explaining what you have.
I will get you one tonight. Thanks :)
The weird thing about it, is what appears to be the primar winding is connected to the heatsink(a sheet of metal) that the voltage regulators are connect to.
Sorry it took so long, but here is the pic. I put a ballpoint pen next to it so you can get a size reference.
This is an old version of UPS. The two transformers are 60 Hz (or 50 Hz if Europe) which are good to salvage. You may find some rectifier diodes used for charging mode. There will be some power transistors, likely MOSFET's used for and H-bridge for generating the modified sinewave. The rest of the electronics if for sensing of A.C. and charging control. You may find a 24v DC power relay for making the AC crossover from mains to UPS output.
New version UPS's use high frequency switching circuitry for DC boost. They are much lighter weight as they use small high frequency ferrite transformers.
I have very similar transformers from a UPS. You say they are for the output side, as in, take the 24V modified sine wave in, and transform it to mains level? Thus it would be possible to use them in reverse for very high rated linear supplies, taking 120V wall in and 24V out?
I had always figured they were input transformers for taking the 120V wall down to battery level for charging, but it makes much more sense that they are outputs. The UPS I scavenged them from was something like 3000VA, so they are massive transformers.
As far as discharging the caps - look at the capacitance rating on them. It is probably in the 1000's of microfarads. Just pick a resistor that won't dissipate them too fast, but not too slow either. And make it a high enough power resistor. 1kohm, 10W for safety, or the 10ohm 10W suggestion made before, depending on size and voltage of the caps. They should be discharged quite a bit by the time you get to them.
I'm sorry, so what are they? Step-down or Step-up?
Also why are the transformer coils connected to the heatsinks(with wires) that the voltage regulators are attached to?
They are used in a step up application here. But technically transformers are bidirectional. If you apply line voltage to what was the output it them becomes a step down transformer.
Most likely they have the leads attached to the heat sinks because of the type of switching system they use. Its normal in many UPS designs.
I should be able to use them as linear transformers though? Connect them right to mains?
I think it should work just fine but be aware that your output voltages will be lower than what they originally used as an input voltage when used in the inverter.
But being designed for inverter use your going to have some super reserve capacity if you need to ever overload them!;)
