RS232
Spasm
Hey all,
Anyone can help me regarding data transmission? I've been using the 16f877 to send serial data thru UART and reading the data from windows hyper terminal. Every cycle of lets say 1 second, the PIC will send out the number 5 and 6. On the terminal side, every 1 second, the terminal will print out "5656565656565656565656" and sometimes it has shorter fives and sixes. Why is this so? The rate I'm sending for both side are 9600,N,8,1. Can anyone help?
Thank You
Spasm said:
Hey all,
Thank You
There's a fair bit of info on RS232 in my tutorials at http://www.winpicprog.co.uk. Are you using a hardware or software USART?, and what actually are you trying to send?.
Hi nigel,
The USART im using is built in the PIC(hardware). Therefore everytime i send, I just movwf into TXREG. The data I'm sending is a 8 bit timer1 value. I've tried using 7 bit value ascii "5s" and "6s" but it still comes out alot of fives and sixes at the PC terminal end. Dont really know why.
Spasm said:
Hi nigel,
What values are you putting in the setup registers?, these are the routines from my tutorial, using a 20MHz 16F876.
;USART Serial routines
SER_INIT
            	BSF     STATUS, RP0           ;select bank 1
     		MOVLW   d'129'                ;9600 baud @ 20 Mhz Fosc +0.16 err
     		MOVWF   SPBRG
     		MOVLW   b'00100100'           ;brgh = 1
     		MOVWF   TXSTA                 ;enable Async Transmission, set brgh
            	BCF     STATUS, RP0           ;select bank 0
     		MOVLW   b'10010000'
     		MOVWF   RCSTA                 ;enable Async Reception
            	RETURN
XMIT_RS232  	btfss   PIR1,	TXIF 	      ;xmit buffer empty?
     		GOTO	XMIT_RS232            ;no, wait
     		MOVWF   TXREG		      ;now send
                RETURN
Rcv_RS232   	BTFSS   PIR1,	RCIF 	      ; check for received data
     		GOTO    Rcv_RS232
                MOVF    RCREG,	W
                RETURN
With a 4MHz clock SPBRG=25 and BRGH=1. I'm presuming you are using a MAX232 (or similar) for the interface, the hardware USART requires an inverter to feed RS232.
Hi Nigel..
Yeap..exactly the same startup configuration. I'm using 4Mhz so SPBRG is 25. For transmission, I've used the same codes too. I've configured one of the PIC pins to blink a LED everytime there's transmission. An I've only seen one blink every cycle(nearly 1 second per cycle). But then terminal reads multiples of the same data(each blink).Any idea?
Thank you
Spasm said:
Hi Nigel..
Thank you
You've got BRGH=1 as well I take it?.
You didn't mention how it's interfaced, are you using a MAX232?.
Hi nigel,
Yeah....BRGH is 1....my interface chip is MAX233CPP..internal capacitors...should be okay i think...its the same with 232..hrmmm....
Could be a baud rate mismatch. Maybe you should try using a different terminal program, and disable all flow control. Try this one:
https://bray.velenje.cx/avr/terminal. I have successfully used it a lot of times, and it is good (except for some nag message from time to time, even though it is freeware).
Jem
