RS232 to USB converter
Boncuk
I have two components which want to connect to each other.
The first is a combined multimeter with integrated oscilloscope (brand Unitrend) and the second one is a fully functional Toshiba Libretto CT50 palm top with windows 98 installed.
The palm top has no USB interface but is very small (taking up little space on the workbench) with a display size of 10" diagonally, which I could use to display the oscilloscope with higher resolution than that provided by the LCD-screen in the Unitrend multimeter.
The Libretto has a full functioning (bidirectional) serial port which I used to program SPS devices while laptops generally fail since their serial port doesn't allow handshaking operations.
I found a chip which might suit the needs, the FT8U232AM (Future Technology Devices Intl.).
Will this work for my application? (Data sheet attached)
Boncuk
  • FT8U232AM.pdf
If the scope only has USB then it won't work. That chip is designed to connect to a host, not a device.
Thanks for the advice.
Do you know of any chip meeting my requirements?
Boncuk
I'm now confused. I found the Libretto and according to that page it doesn't have RS232 but does have USB. Is yours an older version or something?
Hi Mike,
it's a Libretto 50CT including a docking station. The bare device doesn't have any external connector except for a card connector for CD-ROM or floppy drives.
The docking station has a serial port, a 15pin high density video connector, a parallel port and two PS2 connectors to connect external mouse and keypad.
Connectors from left to right: mouse, parallel port, video connector, keyboard connector, serial port.
As already stated, the serial port is capable of handshaking.
It must be a quite old model since it was optimized for windows95, but works with windows98 like a charm.
Regards
Boncuk
Maybe something like this will help:
Link
You can find it in any computer shop or service. Also they come with most of mouses and keyboards and a lot of people dont use it, they use USB.
I have mouse with USB connector and with this adapter It was connected to PS2 port.
Same is with keyboard.
Maybe it will work?
You dont need another keyboard :)
