Review my temperature controller project.
alec_t
Most Helpful Member
There is no supply decoupling for the IC.
Can a stereo jack handle the current you want to control?
With only 6mA base current the TIP41C collector current may be as low as 90mA.
There are much better transistors than TIP41C (higher gain, lower saturation voltage).
Deeg
I appreciate you taking time alec_t. :) I have a couple of follow-ups:
I have no idea what this means. Can you explain please?
How can I figure this out? Is this the kind of thing that would be on a spec sheet for a jack? I've been going with the "it works so it's fine" methodology. :)
Do you have suggestions? I want to learn this stuff so that I can choose the right transistor in the future. Thanks!
alec_t
Most Helpful Member
Then should you be posting circuits on Instructables? Other people may build them and find they don't work as expected.
Google 'supply decoupling'.
How much current do you want to switch/control? What is the voltage? AC or DC?
A reputable manufacturer's datasheet should include voltage and current ratings.
Ok for your own use; but not if you're publishing circuits for others to use.
Personally I would use a 'logic level' N-channel MOSFET with a low (<0.1 Ohm) Rds(on) spec and a generous voltage rating to suit the anticipated load.
EE World Online Articles
Loading
