I stand by my original comments. This is not a power resistor, but it will blow with a lot of power if Line and neutral are reverse wired in house. even if TV is correct with 3 pronged plug.
The correct value resistor is FAR too high to blow, on the circuits I checked they were either 4.7M or 10M - so it certainly wouldn't blow, and is designed to be used either way round.
Not according to UL requirements. it is 3.5mA at 60Hz leakage to ground MAX per stationary unit.
Again, you're quoting the wrong thing - we were discussing a resistor between earth and neutral blowing - this isn't anything to do with UL specs (which apply to the unit), but to the possible voltage difference between earth and neutral, which can be a few volts and enough current to be useful (or in this case to blow a low value resistor incorrectly connected across them).
Be a bit more 'exciting' with the mains plug reversed though
They curbed using 2 pin plugs since VGA ports were added to TV's and monitors to reduce emissions.
This unit is 3 pin, unless a cheater cord was used.
It wasn't clear if the unit stopped working or it just started to fizzle. Nor was it clear what R values were originally there and replaced with same value and power rating and if in close proximity to a PTC which will regulate at 85'C during protection.
Burnt R can be 200K 1/4W
As I indicated as CCFL's age they draw more power which would only affect series power drop Resistors.
A small increase in CCFL current isn't going to blow a surge limiter, even a LARGE increase in CCFL current wouldn't, the worst possible case scenario is that the PSU would current limit.
But as someone who repairs such things professionally, it doesn't happen - even assuming you could get excessive consumption to that degree with a CCFL (which I seriously doubt) the inverter protection circuit shuts it down long before the PSU would get involved.
Putting 120V across a 10K R used to bleed a Y2 Cap would certainly do that and still work as a TV unit with SMPS isolation but noise interference. This could only happen if Line & Neutral were reversed unintentionally. ( DIY wiring by someone)
This is how I would show schematic. Feel free to correct any assumptions.
That's looks pretty well what we've all been assuming.
Incidentally, it's fairly common for such safety components to go to earth from the output of the bridge rectifier, making the leakage equal regardless of plug polarity.
NOTE: CX101 means it is an X rated Cap line to line.
CY101 means it is a Y rated cap. Common mode to ground
Cap must be film Y rated for the Y rated position.
The resistor should a similar special safety component, and not just a normal resistor - and certainly not just a 1/4K one.
CY101 makes the antenna slightly hot ( < 3.5mA)
edit... ( but only if you got no safety ground and a miswired AC outlet. )
It's common (and perfectly normal) to get a slight 'tingle' off class II AV equipment.
