Replacement Pilot Lamp for Sony ICF-9650W radio
Speakerguy
Active Member
I have this 1970's era transistor radio and the front panel light went out. I pulled everything apart and find a little bulb that's burnt out in the front panel. It has a glass envelope, no metal base (just two wires going straight to the glass envelope on the bottom). It is 0.1650" diameter (4.19mm) x 0.414" (10.5mm) long. It looks like it is fed off two wires coming straight off a secondary of the transformer (haven't tested voltage).
Any idea on a replacement given the dimensions? Thanks,
After doing some looking, I think it is a T1.25 type incandescent lamp. No stock at digikey, but I will keep looking. It also looks like I will have to fire it up and test the voltage before I buy a replacement lamp.
if you want it to last (maybe even longer than the rest of the radio) replace it with a white LED a 1n4004 diode and a 470 ohm resistor. since it's being fed AC voltage, polarity doesn't matter.
If I remember correctly they use a pea lamp (6v0. These are hard to replace the LED seems an Ideal solution
Think outside the square then square it.
