Replacement IR LED diode for tv remote
They're a pretty common item, you can even find them on Amazon. If yours is a through-hole round LED, it will likely either be 5mm or 3mm. You can measure the diameter with a ruler. The wavelength used on TV remotes is usually 940nm.
You can find IR LEDs easily online. Some sources are Digi-Key, Mouser, Arrow, and RS Components. These suppliers sell QC-passed products. IR LEDs are also available at Amazon, eBay ,AliExpress ,Banggood etc. But beware! Not all AliExpress and Amazon sellers are dependable. You have to see the reviews and choose a trusted one. You can also search at a local electronics shop, repair store, or a TV or remote repair service.
Are you sure it's a bad diode?
They do fail - I used to have a drawer of replacement IR LED's at work (from RS Components), the main problem was selecting which one to order, there's a HUGE number of different ones. Another common failure was the reservoir capacitor (the 'big' one across the battery), less common was the driver transistor.
By far most faults were mechanical and abuse, dropped, liquid intrusion etc.
I used to have a big box (think CRT TV box) full of scrap remotes for parts, great for when you wanted a battery contact, a keypad, or even an IR LED :D
My first repair and SMD soldering was actually a Sony TV remote 5 years ago.
I thought also that IR LED was faulty, turned out it was a split hair broken trace at a resistor joint.
I think everyone (inexperienced) assumes at first that IR LED is bad, so I just wanted to get actual confirmation if the LED was tested or it's just a guess.
Mobile phone cameras are sensitive to IR light. Point the suspect remote very close towards the camera lens in a subdued light room, press any button and you’ll see the LED lighting up.
See the photo.
It is blurry as the camera focused on the background.
SOME phones are sensitive to IR, many (particularly modern ones) include IR filters, and no longer show IR.
Nigel;
That is the reason I mentioned that the room should have subdued light such that the camera’s sensitivity is wide open, it can be faintly seen.
You should have a DMM to test the battery voltage and diode test mode would indicate the IR less than 1.2V, about twice that of a silicon diode. Then report back. The lens viewing half angle can be estimated by inspecting into it with a bright light.
