Relay!!!???
yes i have 15k resistor then 1n4004 with the cathode to the right like on the diagram have i wired this one wrong?
If you have the 'bar' mark of the diode as shown in the diagram , thats correct.
Also you should have the Line input to pin#2, via the resistor and the diode and the Neutral to pin#1
Do you have a picture of the Timer wiring that I could see.???
The Timer unit should work without the relay connected, it should give some indication that is powered up.
Are you sure the Timer is a MEU11 or 17.???
meu11 and i had it wired line to pin 2 neutral to pin 1 the diode is the same as picture and i will try and get a picture but where i have placed it isnt easy and my solderings not the best so it doesnt look neat lol
if i cant get these timers working is there any other small timers that will do the same job switch 230v lighting
this is the best pic i could get i dunno if you can make it out
many thanks
jak
does this help?
hi Jak,
Sorry but the image doesn't really make clear how its connected.
Have you tried just the basic set up as shown in fig#6 of the Timer datasheet.?? , using the 15K and diode and relay as shown.
The Timer should show signs of being powered up, on the front panel, ?? Let me know what you see.
thats how its wired, and i see nothing it doesnt start up at all i have contacted timeguard and they dont know whats wrong with it
The only suggestion I have is to get Rapid to replace the item under warantee, it may be faulty
Did you at any time reverse the diode or connections... I have to ask
no but the thing is i have 4 of them and all 4 are not working so that makes me think it must be me? i will draw out what i have done.
this is just a quick paint picture but is exactly what i have done
Checked the fig #6 numbers against the drawing you posted, looks OK to me.
On fig6, it shows pin4 nearest to the PCB edge, is that how you have it wired.??
i dont understand what you mean but in all the fig's it shows that pin 1 at the top of the unit and it outlines the shape of the unit so you can tell what pin 1 and 4 are so they are correct but i just cant understand why im not getting anything on the screen of the unit
Like this image, from the datasheet.
I would contact Rapid technical support, from re checking the data sheet and your drawings the Timers should work
ok thanks for the help are there any other timer modules that work or maybe even use something like a pic of some sort to turn lights on and off i nee it to be 24 hour time switch
I use the power socket and plug in type, mechanical switches 24hr in 15min intervals, also the plug in type with LCD display.
On the button cell within the MEU timer, is there a thin insulating strip that has to be removed for the cell to make contact.??
doesnt look like it and i do to but i basically this is for my marine aquarium i have 3 extention leads with 4 timers plugged in and im making it into a mini distribution box with digital timers i like diy projects and enjoy electronics so thought id try these digital timers and i wanted to go to use it because it can be a small digital timer that can be hidden away or in this case it has screens so i can have them on display.
ok i have just got off the phone to timeguard again and for the 3rd time ive had different information from them, he said now that its 12v or 24v unit im feeding 22v ac into it but he mentioned something about dc and when i quoted from their description saying that it can be powered directly from mains with only a relay resistor and diode he said o o ye thats right so im really confused now
I can understand your confusion, they seem to be giving ambiguous information to you.??
Whats your location.???
I'm in Essex and all they keep saying is our engineer will call you tomorrow will t make a difference using fig 7 a 1w 7.5k resistor on each line and neutral? And it would explain why the unit won't turn on if I'm ment to be feeding it dc instead of ac
So much for their datasheet, showing fig #6 with 15K and a diode.!
I would like to know what their engineer has to say when he has called you, please let me know.
yes i will do, do you reckon thats what it could be i dont want to put a 12v dc feed to it just incase, what i dont understand is im talking to their technical support team surely they should have the awnsers but all they say is o yes follow figure 6, 7 or 8 and that will be ok he said to me that i shouldnt be using a 15k resistor i should be using an 18k to bring it down to 12v, i asked him why that would make a difference when he told me the unit should be powered with 12v or 24v supply but he wouldnt say ac or dc
is there any other module or design, can you use a pic as a timer?
