Real time freq correction problem
Rosco101
Hi All
Hopefully some bright spark can assist me with the following problem.
I’m looking for a simple method to perform a real time frequency shift to correct an electronic speedo.
The sensor outputs a 12v square wave signal to the speedo
I looking for an adjustable range of around +/-12% with a resolution down to .001%, this will allow me to experiment with various gear ratios.
Commercial products are available for $100-$200, like Yellow Box or Speedo Healer but I was hoping to avoid the cost and I enjoy building projects.
Any suggestions or cct diag ideas would be much appreciated.
I am also building a shift light, fairly simple overspeed cct using a latching freq to volt converter. And a gear position sensor for which I’m thinking of modifying an expanded scale led volt meter (my bike has a gear position sensor for the fuel computer) to drive an LCD display. A little rough but it may work.
I don’t usually use this type of forum as I don’t have much to contribute in return (guilt) but hopefully someone can assist.
Cheers
Ross :D
Rosco101 said:
Hi All
Ross :D
The only solution I can think of is to use a frequency-to-voltage conversion and voltage-to-frequency. ICs are available.
The only solution I can think of is to use a frequency-to-voltage conversion and voltage-to-frequency. ICs are available.[/quote]
Not a bad idea at all!
Using DIP switches to add or subtract various resistors in between the two
converters might just be the ticket.
Ross
