Read/write serial Eeprom 24AA16
revave
Hello,
For an appplication i need an external memory to store some data.
Therefore i will use an Eeprom from microchip, type 24AA16, which can be written and read by using the I2C protocol.
In a program i try to write data to different locations of the memory (Eeprom) (8 levels possible, selected by bit 1, 2 and 3 of the controlbyte).
This is done by using some lookup tables.
As a test i will read back the complete memory and write it to hyperterminal (using serout).
Well, as you can imagine this is going wrong. I think the problem has to be something to do with the I2CRead instruction.
Reading the datasheet i found some rules.
- The controlbyte has the format 1010ABCx. A, B and C are selectionbits for the level (block) of the memory (8 blocks of 256 byte available). x is used for write or read action (will be controlled by the I2CWrite and I2CRead instructions).
- The I2C write sequense seems to be the same as used in the I2CWrite instruction (see image 1, byte write)
- The I2C read sequence is different and i think the problem can be found here. For random reading (this is what i want to use) the internal Eeprom addresscounter must be set first. This is done with a write instruction. Then - without a stop - a read instruction is folowing to get the data. (see image 2, random read)
So, it seems to me that i have to write a special routine for reading out the Eeprom by using the lower level I2C instructions.
I tried to do this, but do not know how to handle the acknowledge bit in case of reading out one byte per instruction.
In the sourcecode below, i've tried to use the normal I2CRead instruction, but that doesn't work. Also the readout of the Eeprom is attached as txt-file.
Hopefully someone has some experiance with this type of Eeprom...
  • cv_control_eeprom.bas
  • EEprom readout.txt
Oshonsoft has an automatic word / byte I2C address... If you declared
Dim addr As Byte
Dim data As Byte
Then it uses a byte address... The 24AA16 needs a word address.... so
Dim addr As Word
Dim data As Byte
Hello Ian,
Below the description from the datasheet.
It says that the word adres is a byte. But i can check it in practice.
And how about the read action?
4.1 WRITE OPERATION
Byte Write Following the Start condition from the master, the device code (4 bits), the block address (3 bits) and the R/W bit, which is a logic-low, is placed onto the bus by the master transmitter. This indicates to the addressed slave receiver that a byte with a word address will follow once it has generated an Acknowledge bit during the ninth clock cycle. Therefore, the next byte transmitted by the master is the word address and will be written into the address pointer of the 24XX16. After receiving another Acknowledge signal from the 24XX16, the master device will transmit the data word to be written into the addressed memory location. The 24XX16 acknowledges again and the master generates a Stop condition. This initiates the internal write cycle and, during this time, the 24XX16 will not generate Acknowledge signals (Figure4-1).
Two things...
First the write process isn't writing properly as you are writing one byte at a time and not waiting 10mS for the chip to do its housekeeping..
IF you do the total write time of all your data will be around 10 seconds...
Secondly! I cant seem to get the I2CREAD working either.... I'll work on it to see why...
aha!!! Found it....
If you are using the weak pullups then you MUST disable them and use external resistors....
To speed things up, you can use page write to get the values in.... To use page writes you really need to use low level routines... There is an example in the help file....
Hi Ian,
I am using 10k pull-up resistors.
Some ports (RA2 and RA3) need a weak pullup and will be used for an interrupt to get the device out his sleepmode (not a part of this program yet).
I can remove the waiting time to speed it up.
I have no experiance with the lower level I2C instructions, so at this time i try tot use the standard instructions.
that gives me the problem with read out. For random readout i cannot use the standard routine, because the write/read format is not compatible with the standard instructions.
if i use I2CWrite1 directly followed with I2CRead, then i am creating a stopbit between the two instructions..
The snippets of code below should provide a framework to fill the entire EEP using single byte writes, and retrieve the entire contents using single byte reads. Haven't had a chance to check it out though (but I've used similar architecture to do "in-house" endurance tests of EEPs).
Generic code for sample write:
'WRITE TO EEP
For block = 0 To 14 Step 2
    block_addr = 0xa0 + block
    For addr = 0 To 254 Step 1
        I2CWrite sda, scl, block_addr, addr, addr
        WaitMs 5
    Next addr
Next block
Generic code for sample read:
'READ FROM EEP
For block = 1 To 15 Step 2
        I2CRead sda, scl, block_addr, addr, data
        Serout portc.3, 9600, #data, ";"
    Next addr
    Serout portc.3, 9600, CrLf
Next block
BTW, addr, block_addr, and data should be defined as BYTE
Hi Ian,
I've tried your code and have attached the program and the readout from hyperterminal.
As you can see, the internal addrescounter of the eeprom is counting up twice at every read from the PIC.
For a try i've changed the addr to datatype Word, but that doesn't gave a good solution.
Also the I2CRead1 instruction doesn't work.
For readout:
How can I build the code with lower level instructions - without a stop in the middle - that the format seems like:
S-1010xxx0-Ack-addr-Ack-S1010xxx1-Ack-data-NoAck-P
I am thinking about (for the first block)......
I2CPrepare sda, scl
I2CStart
I2CSend 0xa0
I2CRecA ???
I2CSend addr
I2CRecA ???
I2CSend 0xa1
I2CRecA ???
I2CRecN data
I2CStop
I do not know how the instructions I2CRecA and I2CRecN are working.
For I2CRecA tmp
Does this mean that the program is waiting for an acknowledge AFTER sending tmp?
For I2CRecN tmp
Does this mean that the program doesn't have to wait for an acknowledge BEFORE reading tmp?
Oh, and thank you for your help for sofar :)
  • test Ian.txt
  • test Ian.bas
I didn't post any code..... I just place a 5mS delay in your write routines and disabled the WPUA reg...
The code works fine for me.....
The only recommendation was to page write the bytes in to save a whole lot of time...
Ok, but if i want to use page write and page read then i have to understand the loverlevel instructions.
Can you tell me how the instructions I2CRecA and I2CRecN are working? There's no clear explanation in the Oshonsoft reference manual..
The two functions are I2C read ack and I2C read nack When you ask an I2C device to do anything it replies with ACK or NACK to signal that your request has been delt with..
Similarly when you are reading you must respond with NACK to continue or ACK to finish correspondence...
I still think the stock functions should work .
Following is tested code. Unfortunately it is tested on 24AA256 because that is what I have on hand.
'Test Code to Read/Write to 24AA256 with 12F683
'General Configuration
    Define CONF_WORD = 0x33c4
    Define CLOCK_FREQUENCY = 8
    OSCCON = 0x71
'Debug Option
    Dim debug As Bit
    debug = True
    debug = False
'Variable Declarations
    Dim control As Byte
    Dim addr As Word
    Dim data As Byte
    Dim _true As Bit
    Dim _false As Bit
    _true = True
    _false = False
'IO Definitions
    Const _trisio = %11111110
    Symbol tx232 = GP0
    Symbol scl = GP4
    Symbol sda = GP5
main:
    AllDigital
    TRISIO = _trisio
    If debug = _false Then
        WaitMs 2500
        Serout tx232, 9600, "I2C EEP Write/Read", CrLf
    Endif
    control = 0xa0
    'WRITE TO EEP
        Serout tx232, 9600, "Writing...", CrLf
    Endif
        data = addr.LB
        I2CWrite sda, scl, control, addr, data
            WaitMs 5
        Endif
    Next addr
    'READ FROM EEP
    While _true
            Serout tx232, 9600, "Reading...", CrLf
        Endif
            I2CRead sda, scl, control, addr, data
            Serout tx232, 9600, #data, ";"
        Next addr
        Serout tx232, 9600, CrLf, CrLf, CrLf
    Wend
End
RS232 output:
I2C EEP Write/Read
Writing...
Reading...
0;1;2;3;4;5;6;7;8;9;10;11;12;13;14;15;16;17;18;19;20;21;22;23;24;25;26;27;28;29;30;31;32;33;34;35;36;37;38;39;40;41;42;43;44;45;46;47;48;49;50;51;52;53;54;55;56;57;58;59;60;61;62;63;64;65;66;67;68;69;70;71;72;73;74;75;76;77;78;79;80;81;82;83;84;85;86;87;88;89;90;91;92;93;94;95;96;97;98;99;100;101;102;103;104;105;106;107;108;109;110;111;112;113;114;115;116;117;118;119;120;121;122;123;124;125;126;127;128;129;130;131;132;133;134;135;136;137;138;139;140;141;142;143;144;145;146;147;148;149;150;151;152;153;154;155;156;157;158;159;160;161;162;163;164;165;166;167;168;169;170;171;172;173;174;175;176;177;178;179;180;181;182;183;184;185;186;187;188;189;190;191;192;193;194;195;196;197;198;199;200;201;202;203;204;205;206;207;208;209;210;211;212;213;214;215;216;217;218;219;220;221;222;223;224;225;226;227;228;229;230;231;232;233;234;235;236;237;238;239;240;241;242;243;244;245;246;247;248;249;250;251;252;253;254;
Look at this fast buffer write using the Oshonsoft Basic , for the IDE 25C256 the EEPROM's internal buffer is 63 bytes long.
I have shown a double write 0 to 63 and 64 to 127.
Modify as required to suit your EEPROM
Eric
'ext eeprom fast write/read
'modified from a web extract.
'18f2550
Define CONFIG1L = 0x00
Define CONFIG1H = 0x0e
Define CONFIG2L = 0x1e
Define CONFIG2H = 0x00
Define CONFIG3L = 0x00
Define CONFIG3H = 0x83
Define CONFIG4L = 0x80
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
Define SIMULATION_WAITMS_VALUE = 1' make this =0 for a PIC
Dim readbfr(63) As Byte  'test only
Dim addr As Word
Dim loc As Byte
Dim data As Byte
'define the SDA and SCL channels
Symbol sda = PORTB.6
Symbol scl = PORTB.7
addr = 0  '1st eeprom mem location
OSCCON = %01110000  '8MHz internal * 4 PLL
'enable SDA and SCL channels
I2CPrepare sda, scl
I2CStart
I2CSend 0xa2  'control byte
'send the mem start address
I2CSend addr.HB
I2CSend addr.LB
'load the EEPROM's buffer, note 24C256 in the IDE has a 64 Byte buffer, check your EEPROM type
For loc = 0 To 63  'page 0
data = loc
I2CSend data
Next loc
I2CStop  'force the EEPROM to write the EEPROM's buffer to the EEPROM's memory
WaitMs 5
'next page 1
addr = 64
I2CStart
I2CSend addr.HB
I2CSend addr.LB
For loc = 0 To 63
data = loc
I2CSend data
Next loc
End
Hello,
So, finally it works. After a few experiments every addres in every block can be written and read out.
The code needs a minimum delay of 5 ms after every write and read action. If a shorter delay or no delay is programmed the read out goes wrong.
But, during most of the test last days i've made the mistake that the instruction "Define SIMULATION_WAITMS_VALUE = 1" was active. So, this gave me wrong timing in the PIC with as result a terrible working of the I2C function.
Also some lookup tables were not correct programmed (see first .bas file). In every for loop - not started with zero - the pointer to the table was wrong.
Below the final (test)code and read out from hyperterminal.
'PIC16F636;  programm to fill eeprom (24AA16) with data
Define CLOCK_FREQUENCY = 4
Define CONFIG = 0x30c4
'OSCCON.IRCF2 = False
'OSCCON.IRCF1 = False
'OSCCON.IRCF0 = False
AllDigital
'Define SIMULATION_WAITMS_VALUE = 1
Symbol scl = PORTA.4
Symbol sda = PORTA.5
Define I2CREAD_DELAYUS = 0
ConfigPin PORTC.4 = Output
PORTC.4 = False
Dim ctd As Bit
Dim addr As Byte
Dim data As Byte
Dim block As Byte
Dim block_addr As Byte
ctd = True
'WRITE TO EEP
block_addr = block + 0xa0
    For addr = 0 To 255 Step 1
        If ctd Then
            data = addr
        Else
            data = 255 - addr
        Endif
    I2CWrite sda, scl, block_addr, addr, data
    WaitMs 5
    Next addr
    Toggle ctd
Next block
'READ FROM EEP
Serout PORTC.3, 9600, CrLf, CrLf, #block, CrLf, CrLf
        WaitMs 5
        Serout PORTC.3, 9600, #data, ";"
    Next addr
Next block
main:
PORTC.4 = True  'indication writing and reading done
Goto main
End
and below the read out..
7;248;249;250;251;252;253;254;255;
2
255;254;253;252;251;250;249;248;247;246;245;244;243;242;241;240;239;238;2
235;234;233;232;231;230;229;228;227;226;225;224;223;222;221;220;219;218;217;216;
215;214;213;212;211;210;209;208;207;206;205;204;203;202;201;200;199;198;197;196;
195;194;193;192;191;190;189;188;187;186;185;184;183;182;181;180;179;178;177;176;
175;174;173;172;171;170;169;168;167;166;165;164;163;162;161;160;159;158;157;156;
155;154;153;152;151;150;149;148;147;146;145;144;143;142;141;140;139;138;137;136;
135;134;133;132;131;130;129;128;127;126;125;124;123;122;121;120;119;118;117;116;
115;114;113;112;111;110;109;108;107;106;105;104;103;102;101;100;99;98;97;96;95;9
4;93;92;91;90;89;88;87;86;85;84;83;82;81;80;79;78;77;76;75;74;73;72;71;70;69;68;
67;66;65;64;63;62;61;60;59;58;57;56;55;54;53;52;51;50;49;48;47;46;45;44;43;42;41
;40;39;38;37;36;35;34;33;32;31;30;29;28;27;26;25;24;23;22;21;20;19;18;17;16;15;1
4;13;12;11;10;9;8;7;6;5;4;3;2;1;0;
4
6
255;254;253;252;251;250;249;248;247;246;245;244;243;242;241;240;239;238;237;236;
8
10
12
14
And finally the code with the (corrected) lookup tables and working I2C. :)
'Block 0
'addr 0..240 reserved for character set
'Block 1
'Block 2
'addr 0..60 reserved for character set
'Block 3
'addr 0..84 reserved for text "CV-CONTROL"
'addr 100..118 reserved for text "SET"
'addr 120.150 reserved for text "START"
'Block 4
'addr 0..84 reserved for text "PROG:   min."
'addr 100..105 reserved for flame quadrant 1
'addr 110..115 reserved for flame quadrant 1
'addr 120..125 reserved for flame quadrant 1
'addr 130..135 reserved for flame quadrant 1
'addr 140..152 reserved for batt symbol
AllDigital
Dim addr As Byte
Dim data As Byte
Dim look As Byte
Dim i As Byte
Dim a As Byte
Dim t As Byte
'WRITE DATA INTO EEPROM 24AA16
'first part of characterset
For addr = 0 To 240 Step 1  'van 0x20 t/m 0x47 (32 t/m 71)
    data = LookUp(0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14, 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12, 0x00, 0xc4, 0xc8, 0x10, 0x26, 0x46, 0x00, 0x36, 0x49, 0x55, 0x22, 0x50, 0x00, 0x00, 0x05, 0x03, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00, 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00, 0x00, 0x14, 0x08, 0x3e, 0x08, 0x14, 0x00, 0x08, 0x08, 0x3e, 0x08, 0x08, 0x00, 0x00, 0x00, 0x50, 0x30, 0x00, 0x00, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00, 0x00, 0x60, 0x60, 0x00, 0x00, 0x00, 0x20, 0x10, 0x08, 0x04, 0x02, 0x00, 0x3e, 0x51, 0x49, 0x45, 0x3e, 0x00, 0x00, 0x42, 0x7f, 0x40, 0x00, 0x00, 0x42, 0x61, 0x51, 0x49, 0x46, 0x00, 0x21, 0x41, 0x45, 0x4b, 0x31, 0x00, 0x18, 0x14, 0x12, 0x7f, 0x10, 0x00, 0x27, 0x45, 0x45, 0x45, 0x39, 0x00, 0x3c, 0x4a, 0x49, 0x49, 0x30, 0x00, 0x01, 0x71, 0x09, 0x05, 0x03, 0x00, 0x36, 0x49, 0x49, 0x49, 0x36, 0x00, 0x06, 0x49, 0x49, 0x29, 0x1e, 0x00, 0x00, 0x36, 0x36, 0x00, 0x00, 0x00, 0x00, 0x56, 0x36, 0x00, 0x00, 0x00, 0x08, 0x14, 0x22, 0x41, 0x00, 0x00, 0x14, 0x14, 0x14, 0x14, 0x14, 0x00, 0x00, 0x41, 0x22, 0x14, 0x08, 0x00, 0x02, 0x01, 0x51, 0x09, 0x06, 0x00, 0x32, 0x49, 0x59, 0x51, 0x3e, 0x00, 0x7e, 0x11, 0x11, 0x11, 0x7e, 0x00, 0x7f, 0x49, 0x49, 0x49, 0x36, 0x00, 0x3e, 0x41, 0x41, 0x41, 0x22, 0x00, 0x7f, 0x41, 0x41, 0x22, 0x1c, 0x00, 0x7f, 0x49, 0x49, 0x49, 0x41, 0x00, 0x7f, 0x09, 0x09, 0x09, 0x01, 0x00, 0x3e, 0x41, 0x49, 0x49, 0x7a, 0x00), addr
    I2CWrite sda, scl, 0xa0, addr, data
    WaitMs 10
Next addr
'second part of characterset
For addr = 0 To 240 Step 1  'van 0x48 t/m 0x6F (72 t/m 111)
data = LookUp(0x7f, 0x08, 0x08, 0x08, 0x7f, 0x00, 0x00, 0x41, 0x7f, 0x41, 0x00, 0x00, 0x20, 0x40, 0x41, 0x3f, 0x01, 0x00, 0x7f, 0x08, 0x14, 0x22, 0x41, 0x00, 0x7f, 0x40, 0x40, 0x40, 0x40, 0x00, 0x7f, 0x02, 0x0c, 0x02, 0x7f, 0x00, 0x7f, 0x04, 0x08, 0x10, 0x7f, 0x00, 0x3e, 0x41, 0x41, 0x41, 0x3e, 0x00, 0x7f, 0x09, 0x09, 0x09, 0x06, 0x00, 0x3e, 0x41, 0x51, 0x21, 0x5e, 0x00, 0x7f, 0x09, 0x19, 0x29, 0x46, 0x00, 0x46, 0x49, 0x49, 0x49, 0x31, 0x00, 0x01, 0x01, 0x7f, 0x01, 0x01, 0x00, 0x3f, 0x40, 0x40, 0x40, 0x3f, 0x00, 0x1f, 0x20, 0x40, 0x20, 0x1f, 0x00, 0x3f, 0x40, 0x38, 0x40, 0x3f, 0x00, 0x63, 0x14, 0x08, 0x14, 0x63, 0x00, 0x07, 0x08, 0x70, 0x08, 0x07, 0x00, 0x61, 0x51, 0x49, 0x45, 0x43, 0x00, 0x00, 0x7f, 0x41, 0x41, 0x00, 0x00, 0x55, 0x2a, 0x55, 0x2a, 0x55, 0x00, 0x00, 0x41, 0x41, 0x7f, 0x00, 0x00, 0x04, 0x02, 0x01, 0x02, 0x04, 0x00, 0x40, 0x40, 0x40, 0x40, 0x40, 0x00, 0x00, 0x01, 0x02, 0x04, 0x00, 0x00, 0x20, 0x54, 0x54, 0x54, 0x78, 0x00, 0x7f, 0x48, 0x44, 0x44, 0x38, 0x00, 0x38, 0x44, 0x44, 0x44, 0x20, 0x00, 0x38, 0x44, 0x44, 0x48, 0x7f, 0x00, 0x38, 0x54, 0x54, 0x54, 0x18, 0x00, 0x08, 0x7e, 0x09, 0x01, 0x02, 0x00, 0x0c, 0x52, 0x52, 0x52, 0x3e, 0x00, 0x7f, 0x08, 0x04, 0x04, 0x78, 0x00, 0x00, 0x44, 0x7d, 0x40, 0x00, 0x00, 0x20, 0x40, 0x44, 0x3d, 0x00, 0x00, 0x7f, 0x10, 0x28, 0x44, 0x00, 0x00, 0x00, 0x41, 0x7f, 0x40, 0x00, 0x00, 0x7c, 0x04, 0x18, 0x04, 0x78, 0x00, 0x7c, 0x08, 0x04, 0x04, 0x78, 0x00, 0x38, 0x44, 0x44, 0x44, 0x38, 0x00), addr
    I2CWrite sda, scl, 0xa2, addr, data
    WaitMs 10
Next addr
'third part of characterset
For addr = 0 To 60 Step 1  'van 0x70 t/m 0x7A (112 t/m 122
data = LookUp(0x7c, 0x14, 0x14, 0x14, 0x08, 0x00, 0x08, 0x14, 0x14, 0x18, 0x7c, 0x00, 0x7c, 0x08, 0x04, 0x04, 0x08, 0x00, 0x48, 0x54, 0x54, 0x54, 0x20, 0x00, 0x04, 0x3f, 0x44, 0x40, 0x20, 0x00, 0x3c, 0x40, 0x40, 0x20, 0x7c, 0x00, 0x1c, 0x20, 0x40, 0x20, 0x1c, 0x00, 0x3c, 0x40, 0x30, 0x40, 0x3c, 0x00, 0x44, 0x28, 0x10, 0x28, 0x44, 0x00, 0x0c, 0x50, 0x50, 0x50, 0x3c, 0x00, 0x44, 0x64, 0x54, 0x4c, 0x44, 0x00), addr
    I2CWrite sda, scl, 0xa4, addr, data
    WaitMs 10
Next addr
'tekst "CV-CONTROL"
For addr = 0 To 84 Step 1
data = LookUp(0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0xbe, 0xbe, 0xbe, 0xdd, 0xff, 0xe0, 0xdf, 0xbf, 0xdf, 0xe0, 0xff, 0xef, 0xef, 0xef, 0xef, 0xef, 0xff, 0xc1, 0xbe, 0xbe, 0xbe, 0xdd, 0xff, 0xc1, 0xbe, 0xbe, 0xbe, 0xc1, 0xff, 0x80, 0xfb, 0x0f7, 0xef, 0x80, 0xff, 0xfe, 0xfe, 0x80, 0xfe, 0xfe, 0xff, 0x80, 0xf6, 0xe6, 0xd6, 0xb9, 0xff, 0xc1, 0xbe, 0xbe, 0xbe, 0xc1, 0xff, 0x80, 0xbf, 0xbf, 0xbf, 0xbf, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff), addr
    I2CWrite sda, scl, 0xa6, addr, data
    WaitMs 10
Next addr
'tekst "SET"
For addr = 100 To 118 Step 1
look = addr - 100
data = LookUp(0xff, 0xff, 0xb9, 0xb6, 0xb6, 0xb6, 0xce, 0xff, 0x80, 0xb6, 0xb6, 0xb6, 0xbe, 0xff, 0xfe, 0xfe, 0x80, 0xfe, 0xfe, 0xff, 0xff), look
    WaitMs 10
Next addr
'tekst "START"
For addr = 120 To 150 Step 1
look = addr - 120
data = LookUp(0xff, 0xff, 0xb9, 0xb6, 0xb6, 0xb6, 0xce, 0xff, 0xfe, 0xfe, 0x80, 0xfe, 0xfe, 0xff, 0x81, 0xee, 0xee, 0xee, 0x81, 0xff, 0x80, 0xf6, 0xe6, 0xd6, 0xb9, 0xff, 0xfe, 0xfe, 0x80, 0xfe, 0xfe, 0xff), look
    WaitMs 10
Next addr
'tekst "PROG:    min."
data = LookUp("P", "R", "O", "G", ".", ":", 0x20, 0x20, 0x20, 0x20, "m", "i", "n", "."), addr
    I2CWrite sda, scl, 0xa8, addr, data
    WaitMs 10
Next addr
'vlam quadr. 1
For addr = 100 To 105 Step 1
look = addr - 100
data = LookUp(0xc0, 0xf0, 0x78, 0x9c, 0xff, 0xf8), look
    WaitMs 10
Next addr
'vlam quadr. 2
For addr = 110 To 115 Step 1
look = addr - 110
data = LookUp(0xf0, 0xe0, 0x80, 0x00, 0x00, 0x00), look
    WaitMs 10
Next addr
'vlam quadr. 3
For addr = 120 To 125 Step 1
look = addr - 120
data = LookUp(0x0f, 0x3f, 0xff, 0xfe, 0xdc, 0xe3), look
    WaitMs 10
Next addr
'vlam quadr. 4
For addr = 130 To 135 Step 1
look = addr - 130
data = LookUp(0x7f, 0x3f, 0x0f, 0x00, 0x00, 0x00), look
    WaitMs 10
Next addr
'batt icon
For addr = 140 To 152 Step 1
look = addr - 140
data = LookUp(0x7e, 0x7e, 0x5e, 0x46, 0x42, 0x42, 0x42, 0x42, 0x42, 0x7e, 0x24, 0x3c), look
    WaitMs 10
Next addr
'check eeprom adresses
t = 0
For a = 0 To 7
    Select Case a
    Case 0
        addr = 0xa0
    Case 1
        addr = 0xa2
    Case 2
        addr = 0xa4
    Case 3
        addr = 0xa6
    Case 4
        addr = 0xa8
    Case 5
        addr = 0xaa
    Case 6
        addr = 0xac
    Case 7
        addr = 0xae
    EndSelect
    Serout PORTC.3, 9600, CrLf, CrLf, #addr, CrLf, CrLf
        For i = 0 To 255 Step 1
            I2CRead sda, scl, addr, i, data  'bit 1 of "con" is controlled by the I2CRead instruction for reading
            WaitMs 10
            Serout PORTC.3, 9600, #data, ";",
            t = t + 1
            If t > 15 Then
                t = 0
                Serout PORTC.3, 9600, CrLf  'start new line after 16 bytes
            Endif
        Next i
Next a
main:
Goto main
End
Now its time to clean up the code (i.e. the case structure can be replaced with for loop, just like the example from Languer).
Finally, thank you all for your great help! I really appreciate it.
