Random cabinet lighting
MrDEB
Building a display cab for LOML and planning on using some LED's for accent lighting.
idea is to use a 4x4 grid of LED's , with 4 LEDs wired in parrell per
each 4 LEDs are connected to a 4017 counter so the LEDs(4 per line) will cycle on and off.
The 4x4 grid has 4 clr leds on each corner and blue leds to complete the grid
4 High powered 140Kmcd clr LEDs and 8-13Kmcd blue LEDs
idea is to create a lighting ripple effect.
perhaps I need to draw out a schematic??
Sounds like you have it solved anyway ;-)
umm, changing accent lightling may prove to be a bit irritating after a while, are you sure you want to go that way, seems a bit cheesy.
cab light schematic
hope this is readable?
plan is to cycle through the 4 seperate set of leds wuith one or more sets on
the and gate needs some redoing but want to turn on 2 sets then 3 sets then 4 sets then all blue etc.
Question on using the 4029
Have what I hope is a working drawing of planned circuit but am wondering why is pin 2 of the 4029 connected to pin 1?
In my planned circuit I added a fourth transistoir and still connected pin 2 to pin 1.
why ???
orginal circuit bit-tech.net | Rainbow LED
attached my planned circuit
  • random lights.doc
The pin 1 to pin 2 on a CD4029 causes the counter to reset to zero and will mess up your 4th output.
I have mood Lights that have a linear triangle ramp generator (a dual opamp) for each colour. Each frequency is slightly different so millions of colours and millions of brightnesses are produced. The oscillators operate at very low frequencies so that the fading is slow.
well what to do with reset??
if pin 1 goes to pin 2 in orginal schematic what should I connect to reset or ??
The 4029 does not have a reset pin like all other counters have. Instead it has 4 preload pins and the pin 1 load pin. When pin 1 goes high then the counter goes to the loaded setting.
The circuit might be much simpler if a CD4060 oscillator/counter replaces the 555 and the CD4029.
But can I adjust the speed?
looked at data sheet ? ofthe 4060 but saw no speed adjustment except adding a crystal??
may just stick with the 4029 but what to do with pin 1??
The CD4060 uses a classic Cmos oscillator made with 2 resistors and 1 capacitor. Use a pot to replace one of the resistors for a speed control.
maybe a different approach?
found this circuit.
maybe easier than using a 4029 or a 4060??
has a couple more caps etc but ??
will simulate in TINA tomorrow as its 11pm+
past my beddy bye
better circuit=simple
after drawing the schmatic using the op amps I see it gets complicated real quick
found the 4510 is same pinout as 4029 but looks easier to use??
I looked at the 4060 but it starts counting small but timing gets longer??
  • random cab1.doc
The 4060 has a built-in simple oscillator. Its outputs 7, 8, 9 and 10 are in a binary sequence. But it doesn't have an 11th output for a reset.
The CD4516 is a binary counter and the CD4510 is a BCD counter. The Carry-out of the CD4510 is used in your circuit to reset it before it gets to a count of 10, so it operates the same as a binary counter.
count to 9 is fine
I really only need to 4 but 9 is fine.
will just add more randomness to the lights.
all clear-4-140,000mcd leds,
4 clear w/ 13,000mcd blue leds
8 clear,
16 all blue,
16 blue and 8 clear
etc.
