shippy__
Race bike quick shift basics........ as my foot puts pressure on the gear leaver the Quick Shift switch senses the pressure and cuts the spark plugs for a set time which enables me to leave the throttle wide open during shift changes
There are 2 types of quick shift sensors each offering there own benefits and negatives
I have a strain gauge type quick shift on my bike
But I want to program the kill times with my onboard ecu at the click of a button...
To do this I need to tap the strain gauge(12v) to the ecu wire (5v) ...... EG when the 12v wire is cut I need the 5v wire to cut instantaneously
Can you guys hold my hand and point me in the right direction for a solid state relay that would make this work ?
- Basic switch type
- Negatives, have been known to fail have been know to be extremely touchy causing high sides, low sides and thousands of dollars of damage. Flog out easy and get all loosy goosey
- Positives Onboard ECU has complete control of the cut times and is completely programmable for different rev ranges and gears.
- These are operated by the Onboard ecu feeding out 5v through the switch to earth and when the circuit is broken the ignition is cut or vice verser for NC/NO which ever way it is set up.... Ignition cuts can be from 20ms to 200ms
- Strain gauge type
- Negatives, fixed ignition cut time 80ms
- Positives, Extremly reliable, don't flog out
- These are operated by intersecting the 12v ignition wire, opening and closing the circuit for 80ms, this 12v wire also powers the strain gauge module
