Hi, I'm new to this forum. Have electronics background, but long time have not been practicing. So, I have lost knowledge of calculation of simple BJT or even looking at data sheets.
Right now, I'm making a R/F remote control switch for 240v wall light.
Thinking of saving the hassle to build the R/F sectioin, which most of the time not working in my case, I have bought an inexpensive remote control doorbell and make a modification from there.
I need a circuit that can do the latching at the rising edge of a clock and stays "High" at the fall edge. then the relay will go "low" at the next rising edge of the clock.
All I can think of is to use a 4017 decade counter and have it count 0,1 and reset back to 0, which means only 2 output. The relay will be tie to one of these output. The CLK of the 4017 will be fed from the output of the R/F Remote control.
The problem I'm facing right now, is the output of 4017 does not have sufficient current to drive the relay of 5V (120ohm, which is ard 40mA).
Base on the 4017 data sheet here https://www.fairchildsemi.com/ds/CD/CD4017BC.pdf
can anyone tell me what is the max output current of the decoded output if the VDD to the chip is 5V?
how can I modify to drive the relay?
Maybe someone have a better idea to do a latching circuit other than this of mine.
Thanks in advance for any help and suggestions.
