question about switch
wejos
hi guys,
two terminals shorted labeled as SW Power in panel 1 of the MOBO will cause the CPU to turn on. Sometimes a switch called micro-switch is used to short these two terminals. I also noticed that printers use the same turning-on and turning-off style, a momentary shorting of two terminals will turn on the printer.
my question is i don't know the name of this switch, i've seen micro-switch but they are large ones compared to, say for example the ones used in printers. the electronic-store people were laughing at me since i did not know the correct name of the part. I had trouble explaining to them what i wanted to buy. can you please teach me the name of this switch?
as usual thank you very much for your help.
-SPST (means it has 2 terminals only)
-momentary action (means it only works when held down)
-normally open (means the contacts are normally OPEN, then close when activated)
-pushbutton (refers generally to most of these type devices)
-tact switch (refers to the tiny square ones they use on PCBs)
So a "SPST momentary-action normally-open pushbutton" should get you one that mounts in a front panel etc. For the real tiny ones to be soldered onto a PCB tell the jerks it might be called "tact switch".
Kindof ironic since "tact" is something they seem to be lacking...
LMAO
you said it
tact switch, a "SPST momentary-action normally-open pushbutton", thank you very much for your help Mr RB.
tact switch
tact switch
