What is the best way of PWMing about 5-10 RGB LED's using a single 16f628A? I know the hardware PWM on is only a single pin which wont do for RGB and apparently its not great to use the software PWM because it cant do anything else in the background.
If every RGB LED will be the same colour, at the same time, then I happily use a 12v RGB LED strip, connected to 3 pins of a PIC (16F628a or 12F863) via something like a ULN2003AN and doing software PWM... which is not so bad, really.
If you do want all the LEDs to be different colours at different times, then that's a different problem, but one I'd be very much interested in hearing how you resolve...
Good Day,
I used the software PWM implementation method. I utilised 3 digital IO pins of the PIC to control 3 N-Channel MOSFETS. one per color. The Pic only controls the MOSFETs which are responsible for driving the Load of LED`s.
It has worked very well thus far, the only thing I found esential was to use a 20MHz crystal so that the PWM can have a decent refresh rate.
If you would like my HITECH C code as a guide please PM me.
