PWM IC
I still don't understand. You said:
shortbus= said:
I've posted the original of that circuit several times, and have always been told it is no good.
But it is still not clear which circuit you believe is "no good." Any links to those anonymous posters who claim it is no good? Simply put, I find it hard to believe that such a successful chip is "no good." Mayby posting the design that is "no good" would help clarify that ambiguity.
shortbus= said:
As one output switches off and the other switches on. Which for motor driving doesn't make a difference. But if using it to drive logic circuits that are edge triggered it does.
I don't understand. Can you expand on that reasoning a little?
Finally, ronv has not said whether he is driving a motor or just daydreaming about PWM. It is hard for me to make that logical jump to assume he is talking only about driving a motor or only about logic circuits.
John
Actually it is for a guy that wants to drive about 15 amps of LED strips with music. So it is music in PWM out.
John
I don't think either is no good! I think both will work!
The one person that sticks out in my mind, saying that the wizmicro circuit is bad is sgtwookie on AAC. But many others over the years have also chimed in, don't have links to them, sorry. The wizmicro design is the one that was said to be no good.
The SG/KA 3525 chip is a good PWM chip in my opinion, not disputing that at all. The L298 supposedly drops too much voltage across it.
On the SG352x series of chips there are two outputs, each capable of 0% to 45 - 49% duty cycle. The only problem is the is a dead time between the outputs, they are not 'seamless'. They say the minimum duty cycle is 45% of each output but can be up to 49%. If you look at the timing diagram, in the block diagram on page #2 of the data sheet https://www.google.com/url?sa=t&rct...51P7VtFlavz3ekKTZUwHvlA&bvm=bv.76802529,d.aWw you can see it. The end of the first duty cycle does not coincide with the start of the second. In the circuits the chip was developed for this wouldn't be a problem. I tried to use it as a PWM to drive some logic and the dead time caused a problem. I wasn't saying Ronv was driving logic or a motor, just making a comment about the SG/KA 352x series of chips. Sorry I broke into the grownups talking. :)
Yes, the 298 does have a lot of drop.
I like the wired or - saves 2 diodes. 1 resistor 1 cap. can't get much simpler than that. :D
Thanks, guys.
I'm in search of a really simple PWM IC, like the SG3625 except able to get a duty cycle close to 100%. It would be nice if it had a spice model - wish wish.:rolleyes:
All I want to do is put a voltage level in and get PWM out - not a power supply or anything.
Do you want to SINK or SOURCE the Load?
What Voltage Level do you want to put in?
A 555 timer circuit can give you an Adjustable duty cycle range between 1 to 99%.
So Almost Completely OFF to Almost Full on.
Thanks, guys.
I have a dumb question about a wired 'or'. with no diodes. How will that work, being that the SG352x chips are of the totem pole output type? With out diodes in the 'or', when one is on the other will sink its output. That is the reason for using two diodes to make the 'or', at least that's how I understand it.
The outputs of that series of chips(SG/KA352x) alternate they have a "small" deadtime between them. I know I'm far from the rest of you guys level of understanding of this stuff, that's why I'm asking.
It's really kind of sneaky. :eek:
If you ground both outputs and add a pull up to say +12 to Vc, the bottom transistors still switch, but they are already at ground. So the only thing doing any work are the top ones.
Chemelec, It's like a 0 - 5v sine wave from an op amp so not well suited for a 555.
I had written a similar reply earlier, but was waiting to see whether I had a chip I could test for the effect of the deadtime. I didn't and the time got away from me. However, looking at the deadtime resistor value vs. discharge time figure, we can see that deadtime does not go to zero.
I am not certain how that would effect the OR'd output in real life, but it may cause a glitch in the output. For example, at 10 KHz, the period is 100 µS. A 1-µS deadtime when both of the top output transistors are off would limit the theoretical duty cycle to 99%. Perhaps more important than that "glitch" would be the heating from turning the power mosfets on and off.
John
Edit: I just noticed that the attachment I had uploaded for my previous draft wasn't deleted and apparently can't be deleted. Please ignore what is just a duplicate of ronv's attachment.
Interesting experiment..
I modeled it in spice using a big old PFET (IRF4905) running at 40Khz. I used the PFET so the current would be highest at 100% not 0%.
With small C and large R for the frequency set, the FET never turns off during the dead time so very little added power in it. The worst is where it just turns off of course, but this would happen in any case. If you lower the frequency enough that the FET turns off during the dead time, the duty cycle is low enough that the power in the FET is less than having it switch at the higher frequency. I looked at a few faster FETs, and you could find one where it just turned off during the dead time and the power was about 7% higher during the dead time than during the previous 'real' period.
OK, another dumb question. If the outputs(pins #11&#14) are grounded, where does the output come from then?
I have tried to draw the changes with Paint -- not very good.
By grounding the outputs, you effectively remove the bottom two npn transistors. The remaining two are open collector. Add the pull-up resistor to a source (VC) and take the output where I have the arrow. When either or both are on, output will be low.
John
Thank you John! After asking the question and thinking about it while working later I came up with the answer on my own, just like your answer. If I keep at this long enough I'll finally understand more about it. Hard to learn something new at my age, especially something this complex.
Another dumb question about this. When grounding the output pins and using the Vc pin as the PWM output, doesn't this mean that the voltage used to the PWM is then reversed/inverse? Buy that I mean, a lower control voltage gives a longer duty cycle instead of a shorter duty cycle. Sorry if I seem to have hijacked the thread, just trying to learn more.
Yes, that is true. So in some cases you might need to reverse the input or invert the output.
