Quick question regarding thermal fuses which I've not had the pleasure of using, until today. I just need to double check I have the right approach.
Circuit is variable voltage, fixed current of circa 500mA which I'll refer to as current
If I have a transistor shunt set at 36V it could, in an edge case, heat up and destroy the transistor. If I were to use a thermal fuse in-line with a rating of <current it would trip before the 36V is reached while >current would never trip.
This assumes the heat from the transistor makes no difference, but if the fuse is placed right beside the transistor then I can use a fuse value of lets say (current x 2). So the fuse doesn't self-trip, it relies on the transistor heat to bias it.
Thanks, Andrew
Thanks, Andrew
