Prom data format
A Khan
Hello All,
I am working on project which requires modelling of PROM,EPROMs with the data files suplied by the programmer of PROM.
In this case please see the data file "581_u47.txt" and a file edited manually taking about a weeks time "prm_u39.txt". The data file and model file are different however the only requirement of mine is to have the data i.e the first line of uploaded data file:
:10000000 00 00 00 00 FF 3F 7F 3B BB 7F BB 7F 3F 3F 7F 37 50
The required format would be
H00 = H00,H01 = H00,H02 = H00,H03 = HFF,H04 = H3F,H05 = H7F,H06 = H3B,H07 = HBB,H08 = H7F,H09 = H3F,H0A = H7F,H0B = HBB,H0C = H7F,H0D = H3F,H0E = H7F,H0F = H37,
LIKE WISE EACH LINE IS REQUIRED TO BE FILLED IN
PL SUGGEST ANY PROGRAM BY WHICH I CAN SIMPLIFY THE PROCESS SINCE ONE OF THE CIRCUIT HAS 42 PROMS IT WILL TAKE SIX MONTHS TIME FOR ME TO DO IT.
With Best Regards
Khan
  • 581_u47.txt
  • prm_u39.txt
Just write a program that can do it... You must be able to program at least a little bit or know someone who does, that kind of a conversion program would be trivial to write.
Thanks, for your suggestion. Could you pl advise what kind of conversion program will be helpful.
If possible suggest with a bit example.
With Best Regards
A Khan
