Progrmming PIC16F84A
amady
Can or not i'm using 12 volt instead 13 volt during burning to the IC
The spec usually quotes 12V, but for reliability I would advise using 13V, often 12V isn't quite enough - if it works fine with your 12V and the PIC you are using, fair enough. But it may not work with all PIC's.
gogo2520 said:
DIY Electronics KIT81 calls for 18 volts dc or 13 volts ac
DIYK81 requires 14+ volts(dc).......but the PIC16F84A only requires 5v(dc) to operate.......
to operate yes.. but he was talking about programming the part..
Thank!
Thank all my friend... i was use my laptop and it work with RCD programmer... my laptop supply 10V and can be use for burning...
Re: Thank!
Don't forget, it's providing plus and minus 10V, giving a total of 20V, 10V isn't enough to program a PIC.
Re: Thank!
Thank nigel for your advice... actually i was try a simple program to turn on and off led and it work!
williB said:
congradulations..!!
It's really cool when it does what you programmed it to do..
Thank you....
What next?
It just my hobby, just to gain my knowledge... after this I try to make LED flasher... anyway i don't has any idea yet... you has a good website to make my hobby more interesting?
williB said:
Nigel has a great site with lots of interresting stuff on there..
Thanks...
Nigel was use 16F628... but i'm using 16F84A... so how i want to modified the program (.asm)... ?? :?:
amady said:
Thanks...
The differences are very slight, there's a couple of lines included to make the 16F628 more like an 84 - these are commented and should be removed for an 84, you should also alter the header and config settings.
But the main problem is the lack of I/O pins on an 84, far better to use it's modern replacement (the 628) rather than the obselete 84 - particularly as the 628 is considerably cheaper.
Actually now i'm try to modified your .asm file... then the cct also.. when i'm finished all this thing i will publish on web with your permission... :p
That the 16F84A need external ossicalator like RC...??? What about 16F628??
Feel free to do so, but please supply a link to my tutorials 8)
