Programme problem
Nick'
list	p=16F628A
include "p16f628a.inc"
__config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _BODEN_ON & _MCLRE_ON & _WDT_OFF & _CP_OFF
org	0x0000
movlw	0x07              ; I think these should also be added
movwf	CMCON
bsf STATUS,5
movlw 00h
movwf TRISA
bcf STATUS,5
movlw b'00000101'
movwf PORTA
goto $
end
Those were the codes i used in my PIC16F628A. I have connected the power supply of 5V,2A directly to the PIC as 5V is an ideal voltage. Then i connect the RA0, RA1 and RA2 to 3 leds (Directly connected to the pins without any resistors). However my led is not lighting up. Does anyone know why?
Here is my second problem. I am using pickit2 and i would like to debug the code. I went to the debug and select my device(pickit2). I got an error, This is the screenshot.
You need to add a resistor with the LED's. You should also connect MCLR to +5v.
The debugging problem I can't help you with, since I don't have a PICKIT 2.
There is your prove that the code works.
Can you explain to me why i have to connect the 5V to the MCLR?
Secondly, What resistor should i use (how many ohms)?
Thirdly, are the output voltage of the PIC at RA0, RA1, RA2 are 5V equally?
Its simple. You defined it that way.
If you don't want to connect mclr to +5v, or use it as a input then it should be like this:
__config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _BODEN_ON & _MCLRE_OFF & _WDT_OFF & _CP_OFF
Edit: I use anything I can find on my table. Between 270 - 1k works fine for me. But you can calculate the value using ohms law. I don't understand the last question.
list	p=16F628A
org	0x0000
movwf	CMCON
bsf STATUS,5
movlw 00h
movwf TRISA
bcf STATUS,5
movlw b'00000101'
movwf PORTA
goto $
end
You can't debug a 16f628a with out special hardware.
If you want a chip to debug get some 16f88 they can be debugged with out any added hardware
This what you need # PIC16F627A*, 628A*, 648A*
- Use AC162053 ICD header & AC164110 adapter.
Nick';797008 Here is my second problem. I am using pickit2 and i would like to debug the code. I went to the debug and select my device(pickit2). I got an error said:
You don't debugg using the PICkit 2. In Mslab you debug by selecting the 'debugger' heading, then 'select tool' then select '4 MSLAB SIM.
In the upper right hand corner a new toolbar will appear.
Go to view> watch. A new box will appear. Oh, gosh, this is getting complicated.
There are two sections to the box. On the right side, click on the down arrow, which will give you a whole list of the innards of the chip you are using. Scroll down until you find your variables, then, one by one highlight them and click. They will appear, seperately, in the heading. Click add.
Then, back under debugger, click on 'step into'.
Watch the screen where your program is and each time you click 'step into' you will see a bar on the left side step through each line of your program. At the same time, as each variable is acted upon, you will see change in the watch window.
Whew! That's as simple as I can make it. Hope you can follow.
NOTE: This procedure is only for debugging the program. It will not help you debug the hardware.
Regarding my third question. All 3 pins will produce a 5V output. Am i correct? My input to the PIC (vdd) is 5V.
5V, 25mA for each pin.
Yes, i am just messing around. My major problem is i dont have a multimeter, so i cannot measure the current,A , hence not allowing me to calculate which resistor to be used. Given V = Ir, i have to know the current constant in order for me to calculate the resistance to produce 1.5v output for the LEDs.
You can get a digital multimeter at Harbor Freight for around $3 when they are on sale.
But for the problem you cite, you don't need one.
You know the voltage required - 1.5 V (more likely 2 V for red LED)
You should know that LEDs require less than 20 milliamps to operate
You know you have a 5 V supply
Therefore 5 V minus the 1.5 V for the LED equals ???
And that, divided by .020 amps equals ??? in ohms of resistance
The resistor will decrease the voltage or current?
One more question is when i have a 5V supply through a 1.5V LED, will the LED use up the 1.5V, hence the voltage after the LED is 3.5V?
Do you have a basic electronic background? It seems useless to me to go directly to microcontrollers without basic knowledge.
Look at this page. It should answer your questions.
Light Emitting Diodes (LEDs)
You're getting the general idea.
I really strongly suggest you go to **broken link removed**
and let the man explain to you in words, diagrams, pictures and experiments, this facinating world of electronics.
Everything you want to know is explicitly given on that website.
Good luck!
Actually the PICkit2 is a pretty good debugger. But the 16F628A doesn't support debug. The 16F88 does though.
I said that on the first page
