Problem with digital Potentionmeter controling a 555 Timer
anilson1
I am trying to build a simple project which I use a "PIC16F88" communicating through (SPI) with a digital potentiometer DS1267-10 to control the oscillation of a timer 555
Here is the code:
C:
   unsigned char bou[9];
void sendDATA()
   unsigned char counter = 0;     //Declare and initialize the counter
   RB3_bit = 1;                   //Initiate communication through RST
   Delay_us(50);
   while(counter<9)
         if(RB4_bit == 0)
            counter = counter + 1;   //counting pulse on the low
            RB2_bit = bou[counter];  //Send Data
            Delay_us(30);
      RB4_bit = ~ RB4_bit;        //toggle the clock
      Delay_us(50);                //Duty cycle
   RB4_bit = 0;
   RB3_bit = 0;                   //Stop communication through RST
void main(){
   ANSEL = 0;           // pins are configured as digital I/O
   TRISA = 0xFF;           // set PORTA direction to be input
   TRISB = 0x00;           // set PORTB direction to be output
   PORTB = 0;
   do{
        if(RA2_bit == 0)
          bou[0]=1;
          bou[1]=1;
          bou[2]=1;
          bou[3]=0;
          bou[4]=1;
          bou[5]=0;
          bou[6]=1;
          bou[7]=1;
          bou[8]=0;
          sendDATA();
        if(RA3_bit == 0)
          bou[0]=0;
          bou[1]=0;
          bou[2]=1;
          bou[3]=0;
          bou[4]=0;
          bou[5]=1;
          bou[6]=0;
          bou[7]=0;
          bou[8]=0;
          sendDATA();
   }while(1);
The problem is: the oscillator only oscillates at one frequency, by pressing the buttons it does not chance the oscillation speed. Not sure if the problem is on the circuit or on the code. Any idea?
You're using only the H0,L0,H1,L1 pins of the dual pot. The resistance between those is fixed. You need to use a wiper pin (W0 and/or W1).
Your code only has 8 bits.... There should be 17 bits SB, W1bits, W2bits..
I assume you are trying to use stacked... You need to redraw your circuit as well..
Here is the code for single wiper..
C:
unsigned char bou[17];
void sendDATA()
  Delay_us(50);
  while(counter<17)
  if(RB4_bit == 0)
  Delay_us(30);
  RB4_bit = 0;
void main(){
  PORTB = 0;
  do{
  if(RA2_bit == 0)
  bou[0]=0;
  bou[1]=1;
  bou[2]=1;
  bou[3]=1;
  bou[4]=1;
  bou[5]=1;
  bou[6]=0;
  bou[7]=0;
  bou[8]=0;
  bou[9]=0;
  bou[10]=0;
  bou[11]=0;
  bou[12]=0;
  bou[13]=0;
  bou[14]=0;
  bou[15]=0;
  bou[16]=0;
  sendDATA();
  if(RA3_bit == 0)
  bou[0]=0;
  bou[1]=1;
  bou[2]=1;
  bou[3]=0;
  bou[4]=0;
  bou[5]=0;
  bou[6]=0;
  bou[7]=0;
  bou[8]=0;
  bou[9]=0;
  bou[10]=0;
  bou[11]=0;
  bou[12]=0;
  bou[13]=0;
  bou[14]=0;
  bou[15]=0;
  bou[16]=0;
  sendDATA();
  }while(1);
And the circuit.... NOTE 555 ouput needs to go to the top of the wiper as you are trying to keep a 50% duty cycle..
C:
void sendDATA()
  Delay_us(50);
  while(counter<17)
  if(RB4_bit == 0)
  Delay_us(30);
  RB4_bit = 0;
void main(){
  PORTB = 0;
  do{
  if(RA2_bit == 0)
  bou[0]=0;
  bou[1]=1;
  bou[2]=1;
  bou[3]=1;
  bou[4]=1;
  bou[5]=1;
  bou[6]=0;
  bou[7]=0;
  bou[8]=0;
  bou[9]=0;
  bou[10]=0;
  bou[11]=0;
  bou[12]=0;
  bou[13]=0;
  bou[14]=0;
  bou[15]=0;
  bou[16]=0;
  sendDATA();
  if(RA3_bit == 0)
  bou[0]=0;
  bou[1]=1;
  bou[2]=1;
  bou[3]=0;
  bou[4]=0;
  bou[5]=0;
  bou[6]=0;
  bou[7]=0;
  bou[8]=0;
  bou[9]=0;
  bou[10]=0;
  bou[11]=0;
  bou[12]=0;
  bou[13]=0;
  bou[14]=0;
  bou[15]=0;
  bou[16]=0;
  sendDATA();
  }while(1);
And the circuit.... NOTE 555 ouput needs to go to the top of the wiper as you are trying to keep a 5% duty cycle..
And that is the way a schematic should look. Ian, I don't use the PIC parts, but couldn't he just use the on-board PWM, and not need the digital pot, or 555?
Not even that.... Just a bit banged output with variable delays.... Any pic would do it!! But I think this is an exercise..
Yeah, you are probably right:)
I do agree, it is a curious thing to do, using a microcontroller to set the frequency of a 555.
However, as a didactic exercise there are a lot of useful things to learn while doing this.
It actually sounds like it should be a little fun.
Hi guys,
Thank you all for your input and help.
True, this is just an exercise eventually I will remove the timer 555 and connect the pic and digital pot to a motor controller which is controlled by a variable resistor. The timer is just a way to see how the resistance changes, main focus is on the digital pot using a microprocessor (pic).
I forgot to mention the configuration of the digital pot DS-1267-10 is stack, which puts in series the two resistances inside the chip and the output is on the Sout (pin 13) instead of using the W0 or W1. The datasheet is not very clear but I think it says that for stack configuration it uses 9 bits of resolution.
