Problem receiving SMS from GSM using LPC2148[HELP]
Hi, I've connected my SIM300 to LPC2148 via RX, TX & GND lines and successfully transmitted SMSs. Now I've written a code to do the following:
-Initialise the GSM module and wait for an SMS to arrive at the SIM
-Wen an SMS is received, the LPC2148 receives an indication in the form of a +CMTI string
-We extract the location of the SMS on the SIM and read the SMS
-This same SMS is den sent to another number indicated by ########## in the code
But on burning the code it was found that blank messages are being sent to the number ########## instead of the actual received SMS.
Can someone please tell me whats wrong in my code:
#include<lpc214x.h>
extern unsigned char cmgf[]="AT+CMGF=1";	                        //Text format in GSM modem
extern unsigned char cmgsh[]="AT+CMGS=\"+############\"";          	//Mobile number to which the msg is sent
unsigned char cmgr[]="AT+CMGR=";
unsigned char newmsg=0x00;
unsigned char msgid;
void txu1(unsigned char data)				  //Transmit a byte of data through UART1
while(!(U1LSR & 0x20));
  U1THR=data;
unsigned char rxu1()
unsigned char p;
while ((U1LSR&0x01)!=1);
p=U1RBR;
return p;
void sendstring(unsigned char *p)			//Sends a string of data through UART1
while(1)
if(*p=='\0') break;
txu1(*p++);
void delay()							  //delay function
int i,j;
for(i=0;i<60000;i++)
for(j=0;j<200;j++);
void readmsg()
int i;
unsigned char p[21];
sendstring(cmgr);
txu1(msgid);
txu1(0x0D);
txu1(0x0A);
for(i=0;i<6;i++)
p[i]=rxu1();
p[6]='\0';
IO1SET=0x00070000;
sendstring(cmgf);
txu1(0x0D);										// equivalent of
txu1(0x0A);										//	 enter key
delay();
sendstring(cmgsh);
txu1(0x0D);
txu1(0x0A);
delay();
sendstring(p);
txu1(0x1A);
delay();
txu1(0x1A);
IO1CLR=0x00070000;
void uart1_irq() __irq
{					  //ISR if anything is recieved in UART1
unsigned char p[12];
unsigned char q;
int i;
q=U1RBR;
if(q=='+')
for(i=0;i<11;i++)
p[i]=U1RBR;
msgid=p[10];
p[11]='\0';
IO1SET=0x00020000;
newmsg=0x01;
VICVectAddr=0;
void init()					//Initialization of UART0,UART1 and ISR
U1LCR=0x83;
U1DLL=0x62;
U1DLM=0x00;
U1LCR=0x03;
U1IER=0x01;
U1FCR=0X07;
VICIntSelect&=0xffffff7f;
VICVectAddr2=(unsigned int)uart1_irq;
VICIntEnable|=0x00000080;
VICVectCntl2=0x20|7;
int main()
VICIntEnClr=0x00000080;
PINSEL0=0x00050005;
PINSEL1=0x00000000;
PINSEL2=0x00000000;
init();
IO1DIR=0xFFFF0000;
sendstring("ATe0\r\n");
delay();
sendstring("AT+CNMI=3,1,0,0,0\r\n");
delay();
IO1SET=0x00010000;
U1IER=0x01;
while(newmsg==0x00);
newmsg=0x00;
readmsg();
Any help will be greatly appreciated.
Muito obrigada:)
Ok from what i can see.. the UART IRQ is reading 12bytes of data only.. also loops in the IRQ isnt cool i think...
can you set a breakpoint at "delay();"
about here:
delay();//DEBUG HERE
sendstring(p);
and see whats in "p"
Yup.. k.. I've modified the code..
Now, the programmed number ########## receives p correctly. i.e it receives the string:- CMTI: "SM",2
Where "2" is the location in the SIM memory where the received SMS is stored. But the problem now is that I still cannot read the received SMS.
The corrected code is as follows:
#include<lpc214x.h>
  U1THR=data;
unsigned char p;
p=U1RBR;
return p;
while(1)
if(*p=='\0') break;
txu1(*p++);
int i,j;
for(j=0;j<200;j++);
void readmsg()
int i;
unsigned char p[60];
unsigned char q[7];
sendstring(cmgf);
delay();
sendstring(cmgr);
txu1(msgid);
txu1(0x0D);
txu1(0x0A);
for(i=0;i<58;i++)
p[i]=U1RBR;
for(i=0;i<6;i++)
q[i]=U1RBR;
q[6]='\0';
IO1SET=0x00070000;
sendstring(cmgf);
delay();
sendstring(cmgsh);
txu1(0x0D);
txu1(0x0A);
delay();
sendstring(q);
txu1(0x1A);
delay();
txu1(0x1A);
IO1CLR=0x00070000;
unsigned char p[13];
unsigned char q;
int i;
q=U1RBR;
if(q=='+')
for(i=0;i<12;i++)
p[i]=rxu1();
msgid=p[11];
p[12]='\0';
sendstring(cmgf);
delay();
sendstring(cmgsh);
txu1(0x0D);
txu1(0x0A);
delay();
sendstring(p);
txu1(0x1A);
delay();
txu1(0x1A);
IO1SET=0x00020000;
newmsg=0x01;
VICVectAddr=0;
U1LCR=0x83;
U1DLL=0x62;
U1DLM=0x00;
U1LCR=0x03;
U1IER=0x01;
U1FCR=0X07;
int main()
PINSEL0=0x00050005;
PINSEL1=0x00000000;
PINSEL2=0x00000000;
init();
IO1DIR=0xFFFF0000;
delay();
delay();
IO1SET=0x00010000;
U1IER=0x01;
newmsg=0x00;
readmsg();
I'll remove the loop from the ISR later once my code starts working properly.
Thanks alot Atom for helping. I do appreciate it:)
Now only readind the SMS from the SIM is the problem..
Heya Atom!! :)
I've been able to sucessfully receive & read the SMS. But now when I re-enable the interrupt to receive new SMSes, the instant I reenable the interrupt using "VICIntEnable=0x80;" my code branches to the ISR and gets stuck there. Do you know why?
The code is as follows:
#include<lpc214x.h>
  U1THR=data;
unsigned char p;
p=U1RBR;
return p;
while(1)
if(*p=='\0') break;
txu1(*p++);
int i,j;
for(j=0;j<200;j++);
void readmsg()
int i,j;
unsigned char p[500];
unsigned char q[30];
VICIntEnClr=0x80;
sendstring(cmgf);
delay();
sendstring(cmgr);
txu1(msgid);
txu1(0x0D);
txu1(0x0A);
for(i=0;i<130;i++)
p[i]=rxu1();
if(p[i]=='%')
for(j=0;j<10;j++)
q[j]=rxu1();
q[10]='\0';
IO1SET=0x00070000;
break;
sendstring(cmgf);
delay();
sendstring(cmgsh);
txu1(0x0D);
txu1(0x0A);
delay();
sendstring(q);
txu1(0x1A);
delay();
txu1(0x1A);
IO1SET=0x00080000;
unsigned char q;
int i;
q=U1RBR;
if(q=='+')
for(i=0;i<12;i++)
p[i]=rxu1();
msgid=p[11];
p[12]='\0';
sendstring(cmgf);
delay();
sendstring(cmgsh);
txu1(0x0D);
txu1(0x0A);
delay();
sendstring(p);
txu1(0x1A);
delay();
txu1(0x1A);
IO1CLR=0x000F0000;
IO1SET=0x00020000;
newmsg=0x01;
VICVectAddr=0;
U1LCR=0x83;
U1DLL=0x62;
U1DLM=0x00;
U1LCR=0x03;
U1IER=0x01;
U1FCR=0X07;
int main()
PINSEL0=0x00050005;
PINSEL1=0x00000000;
PINSEL2=0x00000000;
init();
IO1DIR=0xFFFF0000;
delay();
sendstring("AT+CMGD=1,4\r\n");
delay();
delay();
IO1SET=0x00010000;
U1IER=0x01;
while(1)
IO1CLR=0x000F0000;
newmsg=0x00;
readmsg();
VICIntEnable=0x80;                                                    // here it branches to ISR
Summary: The first SMS which is received it read correctly and transmitted. But wen I re-enable the interrupt to receive more SMSes, it branches to the ISR andhangs der.. I know it hangs der coz the LED connected to P1.17 lights..
PLs help..
Have you tried clearing the IRQ flag after the interrupt? (well after newmsg=0x01; )
Page 170 states:
"The U1IIR must
be read in order to clear the interrupt prior to exiting the
Interrupt Service Routine"
Heya Atom..
I found the problem. Actually wen I send an SMS, the GSM module sends back a string of the following form: "+CMGS: 65".
So the '+' sign was causing the interrupt. Therefore now I first read the buffer before exiting the readmsg() function as shown:
for(i=0;i<130;i++)
p[i]=rxu1();
if(p[i]=='+')
break;
Now my entire code is working fine!!:)
Now all I have to do is integrate this code with my MEMS code & my project will be done!!
Muito muito obrigada Atom:)
Hi Atom!!
I've integrated the GSM code with my MEMS code but for some reason when an accident occurs or an SMS is receivd, the respective ISRs are not entered.. I just cannot understand why this is happening.
Pls check if I've initialised & handled the interrupts correctly...
Btw the main aim of my project is Accident Detection.. But I also have additional features that depend on the command sent to the GSM module via SMS.
#include<lpc214x.h>
extern int msgflag=0;
unsigned char status;
unsigned char flag;
unsigned char data;
unsigned char cmgr[]="AT+CMGR=";	                        //Text format in GSM modem
extern unsigned char cmgsh[]="AT+CMGS=\"+###########\"";          	//Mobile number to which the msg is sent
extern unsigned char msg[]="ACCIDENT!!!";						 		   //secret code
static unsigned char lat[10];
static unsigned char lon[11];
extern unsigned char cmgsp[]="AT+CMGS=\"+###########\"";
unsigned char recuart0()				// recieves a byte from U0
unsigned char p;
while ((U0LSR&0x01)!=1);
p=U0RBR;
return p;
unsigned char p;
p=U1RBR;
return p;
void senduart1(unsigned char a)					//sends a byte through U1
U1THR=a;
while(U1LSR!=0x60);
while(1)
if(*p=='\0') break;
senduart1(*p++);
void  __irq IRQ_Eint3(void)		//EINT3 ISR
msgflag=1;
EXTINT = 0x08;
VICVectAddr = 0x00;
void delaygsm()							  //delay function
int i,c=0;
for(i=0;i<40000;i++)
c++;
void recgps()			// receives a byte from U0
unsigned char p;
int gps=0;
int i;
while(gps==0)
p=recuart0();
while(p!='$')
p=recuart0();
p=recuart0();
if(p=='G')
else
continue;
p=recuart0();
if(p=='P')
else
continue;
   p=recuart0();
if(p=='G')
else
continue ;
	p=recuart0();
if(p=='G')
else
continue;
	   p=recuart0();
if(p=='A')
while(p!=',')
   p=recuart0();
   p=recuart0();
while(p!=',')
	  p=recuart0();
for(i=0;i<9;i++)
lat[i]=recuart0();
	p=recuart0();
while(p!=',')
	p=recuart0();
	p=recuart0();
while(p!=',')
	 p=recuart0();
for(i=0;i<10;i++)
lon[i]=recuart0();
lat[9]='\0';
lon[10]='\0';
gps=1;
else
continue;
void sendloc()
recgps();
sendstring(cmgf);
delaygsm();
sendstring(cmgsh);
senduart1(0x0D);
senduart1(0x0A);
delaygsm();
sendstring("LAT: ");
sendstring(lat);
senduart1(0x0a);
senduart1(0x0d);
sendstring("LON: ");
sendstring(lon);
senduart1(0x1A);
delaygsm();
senduart1(0x1A);
void readmsg()
int i,j;
VICIntEnClr|=0x80;
sendstring(cmgf);
delaygsm();
sendstring(cmgr);
senduart1(msgid);
senduart1(0x0D);
senduart1(0x0A);
for(i=0;i<130;i++)
p[i]=rxu1();
if(p[i]=='%')
for(j=0;j<3;j++)
q[j]=rxu1();
q[3]='\0';
break;
if(q[0]=='1'){ sendloc();
			  IO1SET=0x00010000; }  // cut-off fuel supply
if(q[0]=='2'){    sendloc();
			      IO1SET=0x00020000; }
if(q[0]=='3'){ int i;
                  for(i=0;i<3;i++)
			        sendloc();
					delaygsm();      //5 mins delay
for(i=0;i<130;i++)
p[i]=rxu1();
if(p[i]=='+')
break;
VICIntEnable|=0x80;
unsigned char q;
int i;
q=U1RBR;
if(q=='+')
for(i=0;i<12;i++)
p[i]=rxu1();
msgid=p[11];
VICVectAddr=0;
readmsg();
void intSetup()		 //This function setups EINT3
 EXTMODE = (1<<3);	// EINT3 is edge sensitive
 EXTPOLAR = (0<<3);					// EINT3 in triggered on falling edge
 VICIntSelect = 0x00000000;		// Setting EINT3 as IRQ(Vectored)
 VICVectCntl0 = 0x20|17;		// Assigning Highest Priority Slot to EINT3 and enabling this slot
 VICVectAddr0 = (int)IRQ_Eint3; // Storing vector address of EINT3
 EXTINT = 0x08;	//Clearing EINT3 flag
 VICIntEnable = (1<<17);	// Enable EINT3
void start()
I2C0CONSET=0x20;
void stop()
I2C0CONSET=0x10;
unsigned char state(unsigned char number)
while(flag==0);
flag=0;
if(status!=number)
{ return 1; }
else
{ return 0;}
void __irq intt(void)
flag=0xFF; 			//update status flag
status=I2C0STAT;				//Read Status byte
I2C0CONCLR=0x28;
VICVectAddr = 0x00;   		//Acknowledge Interrupt
unsigned char read(unsigned char place1)
 start();
 if(state(0x08))
  return 1;
 I2C0DAT=0x38;
 if(state(0x18))
  return 1;
I2C0DAT=place1;
if(state(0x28))
 return 1;
start();
if(state(0x10))
return 1;
I2C0DAT=0x39;
if(state(0x40))
return 1;
I2C0CONCLR=0x04;
if(state(0x58))
return 1;
data=I2C0DAT;
stop();
 return 0;
 unsigned char write(unsigned char place,unsigned char text)
 start();
 if(state(0x08))
  return 1;
 I2C0DAT=0x38;
 if(state(0x18))
 return 1;
I2C0DAT=place;
if(state(0x28))
 return 1;
I2C0DAT=text;
if(state(0x28))
 return 1;
 stop();
 return 0;
void initi2c()
PINSEL0&=0xFFFFFF0F;
PINSEL0|=0x00000050;
 I2C0CONCLR=0x6C;
 I2C0CONSET=0x40;
 I2C0SCLH=80;
 I2C0SCLL=70;
 VICIntSelect = 0x00000000;		// Setting all interrupts as IRQ(Vectored)
 VICVectCntl1 = 0x20 | 9;		// Assigning Highest Priority Slot to I2C0 and enabling this slot
 VICVectAddr1 = (unsigned long)intt; // Storing vector address of I2C0
 VICIntEnable = (1<<9);
void i2cperform()
PINSEL0|=0x00050005;
PINSEL1|= 0x20000000;
PINSEL2|=0x00000000;
initi2c();
write(0x2A,0x18);
write(0x15,0x78);
write(0x17,0x15);
write(0x18,0x0A);
write(0x2D,0x04);
write(0x2E,0x04);
data=read(0x2A);
data|=0x01;
write(0x2A,data);
void initgsm()								 //Initialization of UART0,UART1 and ISR
U0LCR=0x83;
U0DLL=0x62;
U0DLM=0x00;
U0LCR=0x03;
U1LCR=0x83;
U1DLL=0x62;
U1DLM=0x00;
U1LCR=0x03;
U1IER=0x01;
U1FCR=0X07;
void gsmperform(void)
PINSEL1|=0x00000000;
initgsm();
delaygsm();
delaygsm();
void sendmsg(void)
recgps();
sendstring(cmgf);
senduart1(0x0D);										// equivalent of
senduart1(0x0A);										//	 enter key
delaygsm();
sendstring(cmgsh);
senduart1(0x0D);
senduart1(0x0A);
delaygsm();
sendstring(msg);
senduart1(0x0a);
senduart1(0x0d);
sendstring(lat);
senduart1(0x0a);
senduart1(0x0d);
sendstring(lon);
senduart1(0x1A);
delaygsm();
senduart1(0x1A);
sendstring(cmgf);
delaygsm();
sendstring(cmgsp);
senduart1(0x0D);
senduart1(0x0A);
delaygsm();
sendstring(msg);
senduart1(0x0a);
senduart1(0x0d);
sendstring(lat);
senduart1(0x0a);
senduart1(0x0d);
sendstring(lon);
senduart1(0x1A);
delaygsm();
senduart1(0x1A);
int main()
PINSEL0 = 0x00000000;		// Enable GPIO on all pins
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
intSetup();
i2cperform();
gsmperform();
while(1)
if(msgflag==1)
sendmsg();
msgflag=0;
IO1DIR=0xFFFF0000;
IO1SET=0x000F0000;
Can any one halp me in code to solve the error....???
#define CR 0x0D
#include <LPC21xx.H>
#include <stdio.h>
void getstring(unsigned char *);
int getchar (void) /* Read character from Serial Port */
void status_ok(void);
void Serial_Init(void);
void delay(unsigned int n);
void main(void)
unsigned int cnt=0x80,m;
char xx;
Serial_Init();
delay(50);
while(1)
printf("AT\r"); // AT COMMAND FOR INITIALING
status_ok();
printf("AT+IPR=9600\r"); // AT COMMAND FOR BAUD RATE
status_ok();
printf("AT+CMGR=2\r"); // Reading the message detail
// at Index 1 with phone number, data and time
status_ok();
delay(250);
printf("ATD9727855007;\r");//AT COMMAND FOR CALL DIALING
delay(250);
status_ok();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
printf("ATH\r"); // AT COMMAND FOR CALL DISCONNECTING
delay(250);
status_ok();
delay(500);
delay(500);
printf("ATDL\r"); // AT COMMAND FOR REDIALING
delay(250);
status_ok();
delay(500);
delay(500);
printf("ATH\r"); // AT COMMAND FOR ANSWERING THE CALL
delay(250);
status_ok();
delay(500);
delay(500);
void getstring(unsigned char *array)
unsigned char temp=0, i=0;
do
temp = getchar();
*array++ = temp;
while((temp != '\r') && (temp != '\n'));
*array = '\0';
while (!(U0LSR & 0x01));
return (U0RBR);
getstring(y);
while(!(strstr(y,"OK"))) getstring(y);
pointr = strstr(y,"OK");
lcd_cmd(0xc0);
lcd_data(*pointr++);
lcd_data(*pointr);
delay(500);
lcd_cmd(0x01);
PINSEL0 |= 0X00000005; //Enable Txd0 and Rxd0
U0LCR = 0x00000083; //8-bit data, no parity, 1-stop bit
U0DLL = 0x00000061; //for Baud rate=9600,DLL=82
U0LCR = 0x00000003; //DLAB = 0;
unsigned int i,j;
for(i=0;i<n;i++)
for(j=0;j<12000;j++)
#define CR 0x0D
#include <stdio.h>
void main(void)
char xx;
Serial_Init();
delay(50);
while(1)
status_ok();
status_ok();
status_ok();
delay(250);
printf("ATD9790550124;\r");//AT COMMAND FOR CALL DIALING
delay(250);
status_ok();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
do
temp = getchar();
*array++ = temp;
*array = '\0';
return (U0RBR);
getstring(y);
lcd_cmd(0xc0);
lcd_data(*pointr);
delay(500);
lcd_cmd(0x01);
unsigned int i,j;
for(i=0;i<n;i++)
#define CR 0x0D
#include <stdio.h>
void main(void)
char xx;
Serial_Init();
delay(50);
while(1)
status_ok();
status_ok();
status_ok();
delay(250);
delay(250);
status_ok();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
do
temp = getchar();
*array++ = temp;
*array = '\0';
return (U0RBR);
getstring(y);
lcd_cmd(0xc0);
lcd_data(*pointr);
delay(500);
lcd_cmd(0x01);
unsigned int i,j;
for(i=0;i<n;i++)
#define CR 0x0D
#include <stdio.h>
void main(void)
char xx;
Serial_Init();
delay(50);
while(1)
status_ok();
status_ok();
status_ok();
delay(250);
delay(250);
status_ok();
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
delay(250);
status_ok();
delay(500);
delay(500);
do
temp = getchar();
*array++ = temp;
*array = '\0';
return (U0RBR);
getstring(y);
lcd_cmd(0xc0);
lcd_data(*pointr);
delay(500);
lcd_cmd(0x01);
unsigned int i,j;
for(i=0;i<n;i++)
