bananasiong said:Yes. But the taps will become spaces. This is what I observed from theCode:[/QUOTE] The tabs are converted to spaces when it is posted and so there is no way to know if the original code had tabs or spaces. I can't see why it makes a difference anyway. Mike.
Pommie said:The easiest way is to copy it into another program and print it. If you highlight the code in the box and then do copy, you can open notepad, paste it and then print.
Pommie said:There was I thinking I was the only one that still uses PFE. I find the keyboard record particularly useful for manipulating text.
If you have posted it correctly the tabs are NOT converted to spaces. That's the beauty ofPommie said:The tabs are converted to spaces when it is posted and so there is no way to know if the original code had tabs or spaces. I can't see why it makes a difference anyway.
[/c[COLOR="Black"]od[/COLOR]e] tags. They force this site to leave the text alone. It's possible you pasted into another program that changed them, but if they were posted here with tabs then they still had tabs when you copied/pasted.
Highlight the text you want to copy. Hit CTRL-C to Copy (hold down CTRL and hit C (don't worry about upper/lower case - I just did that so the letters were clear for you)). Switch to the program you want to paste in and position your cursor where you want the text pasted. Hit CTRL-V to Paste.nukte said:Sorry to be a total nube, but, can you talk me through that?
