Power electronics project
Coolrui
Hi!
Could anyone give me suggestions regarding a project for power electronics circuits? Would it be good to go ahead with dc-dc converter or does anyone have a better and more interesting suggestion??
Thanks,
Rui
How about a Class H or G power amplifier? Basically it's any other type of amplifier powered by a variable rail supply that's kept as close to the voltage needed by the primary amplifier for the signal it's needed to produce at any given moment. Can be as simple as a buck converter powering a class A amplifier to increase efficiency. Or as complex as buck-boost powering a class D amplifier to minimize switching losses in the output stage. Class H is changed in descrete steps (like low mid and high power modes) and Class G is continously variable, basically run from feedback from the input signal through a control loop.
I think I'll go for a complex buck converter circuit analysis and add or drop stuff as I go along with the procedure.
Thanks for the suggestion
