This is my first PIC project. I have it bread boarded and everything appears to be working, but I was hoping someone wouldn't mind taking a look at the schematic and making sure I haven't done something stupid.
Since the schematic is pretty big, you can find it here:
I'll try and answer a few things up front so people don't have to guess:
1) N1 is a 3.3 V regulator with shutdown capability. B8 turns it on and after the PIC starts, it is held on by the output of RA7. Pin NBP is "noise bypass" -- data sheet just says to put a 0.1 uF cap to ground -- so I did.
2) T1, T2 and voltage divider are for measuring battery voltage. Both T1 and T2 are logic level MOSFETs.
3) U3 is a pressure/temperature sensor
4) U4 is an EEPROM
5) U1 is a 4x20 LCD display from New Haven.
6) I'm not using pull-up resistors on buttons B1-B6 because I have the internal pull-up resistors on CN11 through CN16 on.
7) Capacitor values are uF.
Other than that, I hope it is pretty self explanatory. The PIC reads the pressure and temperature, does some calculations and writes data to the display.
Thanks!
Brad
4) U4 is an EEPROM
Thanks!
Brad
