pic18f pwm problem
Joe G
I've been trying to get my pwm eccp P1A, P1B pins to output pwm. Also trying to get ccp2 and ccp3 to output a pwm. All I can get to output a pwm signal is the P1A and the ccp2 pins, I was able to get all the pwm outputs on a PIC18F45K20 to simulat on MPLAB's sim. but for the last 10 days I couldn't get the same to operate or simulate with the PIC18f46k80. Maybe I missed something or the 'sims' won't work with this chip. thanks for any and all help. I've also moved on from Ass'y to learning C18 so I'm a bit new w/ the C language.
/*			PIC18F46K80    44pin						*/
/** C O N F I G U R A T I O N   B I T S ******************************/
//#pragma config SOSCSEL = DIG			//turn off sosc
#pragma config IESO = OFF, FOSC = INTIO2					// CONFIG1H
#pragma config BOREN = OFF									// CONFIG2L
#pragma config WDTEN = OFF, WDTPS = 32768          // CONFIG2H
#pragma config MCLRE = OFF									// CONFIG3H
#pragma config STVREN = OFF, XINST = OFF                    // CONFIG4L
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF                   // CONFIG5L
#pragma config CPB = OFF, CPD = OFF                                         // CONFIG5H
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF               // CONFIG6L
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF                           // CONFIG6H
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF           // CONFIG7L
#pragma config EBTRB = OFF                                                  // CONFIG7H
/** I N C L U D E S **************************************************/
#include <p18F46K80.h>
#include <timers.h>  // header file
#include <math.h>
#include <delays.h>
#include <capture.h>  // header file
#include <pwm.h>  // header file
/** V A R I A B L E S *************************************************/
// declare constant data in program memory starting at address 0x180
#pragma idata
//unsigned char reg_read = 0;
#pragma udata   // declare statically allocated uinitialized variables
void InterruptServiceHigh ();
void InterruptServiceLow ();
unsigned long  range, n;
unsigned char loc, front, ForB;
int long zone;
/** I N T E R R U P T S ***********************************************/
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh (void)
  _asm
    goto InterruptServiceHigh //jump to interrupt routine
  _endasm
#pragma code InterruptVectorLow = 0x18
void InterruptVectorLow (void)
  _asm
    goto InterruptServiceLow //jump to interrupt routine
  _endasm
//** D E C L A R A T I O N S *******************************************/
#pragma code    // declare executable instructions
	void PING();
	void rotate();
	void go_frt();
	void go_bk();
	void set_pole();
void main (void)
   	CM1CON = 0;
   	CM2CON = 0;
   	ADCON0 = 0;
   	ANCON0 = 0;
   	ANCON1 = 0;
   	ADCON1 = 0;
       	CCP1CON=0;
    	CCP2CON=0;
  	CCP3CON=0;
	CCP4CON=0;
        LATA = 0;
        LATB = 0;
        LATC = 0;
        LATD = 0;
        LATE = 0;
       	TRISA= 0;		//A6,A7 =fwd, rev.   A5=turbo(npn)
       	TRISB= 0b00001111;	//B0,1,2,3 = bumpers;    B5,6=
       	TRISC= 0;  		//C0, C1 steering incoder;  C2,6=steering; C7=PING;  C4,5=sonar incoders
       	TRISD= 0;		//D7=IR-REC;  D0,1= steering limit sw's
       	TRISE= 0;       	//E0=sonar and stuff  FET,
	ODCON = 0;
       	CCPR1L = 0;
       	CCPR1H = 0;
        CCPR2L = 0;
       	CCPR2H = 0;
       	CCPR3L = 0;
       	CCPR3H = 0;
        PR2 = 250;
       	PR4 = 250;
      	CCPR1L = 125;
        CCPR2L = 80;
	CCPR3L = 80;
       	T1CON = 0b00000001;
       	T2CON = 0b00000100;
        T4CON = 0b00000100;
       	//TRISCbits.TRISC7 = 1;  		//	D7 = ccp4
      	INTCON = 0b11000000;
       	INTCON2 = 0b00000000;
       	//INTCON3 = 0b00111000;     //portb ext ie b0,1,2,3 falling edge
       	CCPTMRS = 0b00000110;   //timer allocations for ccp's
       	CCP1CON = 0b00001100;	//tmr1	D4 P1B =right turn sonar, D5   P1A =left turn sonar
        CCP2CON = 0b00001100;	// pwm  RC2   tmr2       		C2    //steering
       	CCP3CON = 0b00001100;	// pwm  RC6   tmr2			C6	//steering
      	PSTR1CON = 	0b00000010;							//P1B =right turn sonar
        //CCP4CON = 0b00000100;	//ccp4 falling edge   tmr1    	C7
       	CCPR2L = 0;
       	CCPR2H = 0;
       	PR2 = 250;
       	T1CON = 0b00110001;
       	T2CON = 0b00000100;
       	TRISCbits.TRISC1 = 1;
       	CCPR1L = 200;
       	CCPR1H = 0;
	//set_pole();		//set loc for org stepper pole loc
	while(1)
		while(! PIR1bits.TMR1IF==1);
	    //rotate();
	    PIR1bits.TMR1IF=0;
	    TMR1H=0;
	    TMR1L=0;
//	LATDbits.LATD6=~LATDbits.LATD6;
	    CCPR1L +=50;
	    if(CCPR1L>=201)
	    	{	CCPR1L=0;
		    Delay1KTCYx(5);
	PSTR1CONbits.STRA=~PSTR1CONbits.STRA;
	PSTR1CONbits.STRB=~PSTR1CONbits.STRB;
	PSTR1CONbits.STRC=~PSTR1CONbits.STRC;
}//main
would I check non access RAM w/ the disassembly file? I did check that and it was okay w/ the code.
Well I finally got my board etched and populated. I've been playing w/ the pwm's and they seem to be working :) I'm taking it as the sim's don't show correctly but in the real world they are:) I took a chance on finishing the board, but it was worth it.. Now to start the serious learning of C coding :D
