PIC Simulator
that one id not voltage
You can only use integer arithmetic, its easy to convert a voltage into an adc count by using a calculator
5V = 1023 adc value
the code above is an analog one
i want you to check it
I did check and I posted the corrected program
i cant test it to hardware
Why cant you test to hardware.???
what is the code above configuration for ? (PIC)
can you tell me how to generate the conf word ?
Which PIC are you using.?
hi TT,
When you post a question you must give more details or explanation of what it is you are trying to do, at the moment I have to keep guessing what you want.:)
Try OPTIONS 'configuration bits'
i try your suggestion
but it have two words
Define CONF_WORD = 0x2F14
Define CONF_WORD_2 = 0x3EFF
what should i select ?
Why have you chosen these CONFIG settings.??
You have code protect Enabled.
i never understand what does CPD and CP for
what does it for ?
i also want to know the other config for
like LVP what it for if we not even programming with low voltage ?
WRT , FCMEN , BOR and etc ?
what does it for ?
Its for when you program a PIC and you dont other people to be able to read the program.
I would recommend you keep code protect disabled for your projects.
hi
how can i set RA0 as analog input ?
for 16F886
hi TT,
This is the Simulator Forum, this type of question should be asked on the Micro-Controllers forum so that other members can answer.:)
Do you mean like this.?
'16F886 and 16F88
AllDigital
Define SIMULATION_WAITMS_VALUE = 1
Define LCD_BITS = 4
Define LCD_DREG = PORTB
'Define LCD_DBIT = 8
Define LCD_RSREG = PORTB
Define LCD_RSBIT = 3
Define LCD_EREG = PORTB
Define LCD_EBIT = 2
Define LCD_RWREG = PORTB
Define LCD_RWBIT = 1
Dim adcv0 As Word
TRISA = 1  'RA0 (AN0) is input
TRISB = 0  'PORTB is output
ANSEL = 0x01
'Initialize the A/D converter
ADCON1 = %00000001  'Make AN0 analog inputs,
'make reference voltage = VDD
ADCON0 = %11000001  'A/D clock is internal RC, select AN0
Lcdinit
loop:
Lcdcmdout LcdLine1Home
Adcin 0, adcv0
Lcdout "adc test=", #adcv0, "  "
Goto loop
End
i think i just need to add extra line
with this one
ANSEL = 0x01
ADCON1 = %00000001
ADCON0 = %11000001
and its works !
problem solved :)
So when are you going to post your next program....;)
