PIC Simulator
yes it work ( a little hard to set )
lets continue ! :)
OK,
Load, F9, run this button1.bas
Select '8 LED Board', set the pins like this image.
Run the 16F4Key2.exe module, set it like the image.
Use the buttons to light the LED's ,, play with inverted buttons and latching buttons,, OK.?
I have seen that the Blog exe has a colour change on two of the check boxes.?? its not a problem I will change it later.
  • buttons1.bas
OK,
it work
just like pust button :)
i also test it the code with my 16F886
its work too :)
it work
its work too :)
Thats good.
I think you should write a simple Basic program of your own and post it, so that I can try it.:)
Choose any modules you wish, lets see what you have learned...I will wait.
OK
For the next part after your testing program...
I think you have a 12F629 PIC on your bench, do you have a PIC programmer.?
An LED and 330R resistor.
If you have it would be a good idea to program a small PIC.
Thats good.
OK
i have PICKIT2
look at my last post
i take the picture of it :)
hi eric
can you tell me how to set/read the analog input ?
We did that in LCDintro1.bas.
Which part do have a problem with.?
EDIT:
Unzip this and watch the avi video
  • TTzip1.zip
example :
if PORTA.0 = >0450 Then
PORTB.0 = 1
else
PORTB.0 = 0
if PORTA.0 = >1250 Then
PORTB.1 = 1
else
PORTB.1 = 0
please fix it !
if you can , i can depelov the code to something else :)
example :
PORTB.0 = 1
else
PORTB.0 = 0
PORTB.1 = 1
else
PORTB.1 = 0
please fix it !
Your code fragment.
if PORTA.0 = 0450 Then ; this can only be 0 or 1 as its a BIT statement
PORTB.0 = 1
else
PORTB.0 = 0
; the ENDIF is missing!
if PORTA.0 = 1250 Then ; this can only be 0 or 1 as its a BIT statement
PORTB.1 = 1
else
PORTB.1 = 0
Post your full program.
Is this what you are trying to do.?
loop:
If an0 > 100 Then
PORTC.0 = 1
Else
PORTC.0 = 0
Endif
If an1 > 110 Then
PORTC.1 = 1
Else
PORTC.1 = 0
Endif
Goto loop
End
  • LCDintr2.bas
TRISA = 0xff
TRISB = 0x00
If PORTA.0 = > 450 Then
PORTB.0 = 1
Else
PORTB.0 = 0
Endif
If PORTA.0 = > 1250 Then
PORTB.1 = 1
Else
PORTB.1 = 0
Endif
the script error
what i mean is if the analog input
of PORTA0 up from 450 it will turn on the led on PORTB0
so , what it will be ? :)
EDIT : with only using one analog port .
TRISA = 0xff
TRISB = 0x00
PORTB.0 = 1
Else
PORTB.0 = 0
Endif
PORTB.1 = 1
Else
PORTB.1 = 0
Endif
the script error
Post #88 shows how to use the adc, just use an0 for 1 adc and change PORTC.0 to PORTB.0
like this one right ?
loop:
If an0 > 450 Then
PORTB.0 = 1
Else
PORTB.0 = 0
Endif
If an0 > 1250 Then
PORTB.1 = 1
Else
PORTB.1 = 0
Endif
Goto loop
End
it still contain error
in line 0003
please check it ! :)
EDIT :
i want to disable the LCD and only use the led for output
loop:
If an0 > 450 Then
PORTB.0 = 1
Else
PORTB.0 = 0
Endif
[COLOR=Red]If an0 > 1250 Then[/COLOR]; the maximum value from the 10 bit adc is 1023!!
PORTB.1 = 1
Else
PORTB.1 = 0
Endif
Goto loop
End
in line 0003
EDIT :
OK,
So you want one adc AN0 that controls just one LED on PORTB.0
Just a minute.
EDIT:
Look at this OneAdc....bas
EDIT2:
Look at this OneAdc_3LED.bas
It lights 3 leds on portb 0.1.2 in sequence
  • OneAdc-1LED1.bas
  • OneAdc-3LED2.bas
OK,
Just a minute.
EDIT:
EDIT2:
thanks , it work
im thinking about making VU meter to replacing LM3914 that doesnt available in my country from this source code :)
i will post the code to make sure
i also want to make documentation about all project that people can do from this thread
in PDF
hi eric
can you tell how to change the analog input to VOLTAGE input ?
i(m going to)have some devices that have a voltage output :)
On OPTIONS select Use Voltages for analog inputs
Or look at the module...image
EDIT:
Look at this zipped avi video, if you want this adc module let me know.
  • TT2zip.zip
i mean at the script
example =
if PORTA.0 > 0.3 Then ' in volt
PORTB.0 = 1
else
PORTB.0 = 0
Endif
also , please check my code
Define CONF_WORD = 0x3f31
Define SIMULATION_WAITMS_VALUE = 1
AllDigital
Dim an0 As Word
TRISB = 0x00
TRISC = 0x00
ADCON1 = 0x8e
loop:
Adcin 0, an0
If an0 < 125 And an0 > 0 Then
PORTB.0 = 0
Else
PORTB.0 = 1
Endif
If an0 < 250 And an0 > 0 Then
PORTB.1 = 0
Else
PORTB.1 = 1
Endif
If an0 < 375 And an0 > 0 Then
PORTB.2 = 0
Else
PORTB.2 = 1
Endif
If an0 < 500 And an0 > 0 Then
PORTB.3 = 0
Else
PORTB.3 = 1
Endif
If an0 < 625 And an0 > 0 Then
PORTB.4 = 0
Else
PORTB.4 = 1
Endif
If an0 < 750 And an0 > 0 Then
PORTB.5 = 0
Else
PORTB.5 = 1
Endif
If an0 < 825 And an0 > 0 Then
PORTB.6 = 0
Else
PORTB.6 = 1
Endif
If an0 < 1000 And an0 > 0 Then
PORTB.7 = 0
Else
PORTB.7 = 1
Endif
Goto loop
End
start from portb 0 for first led
hi
You cannot do this,
if PORTA.0 > 0.3 Then ' in volt; I said earlier that this must be either a 0 or a 1
PORTB.0 = 1
else
PORTB.0 = 0
Endif
I will check your program
Is this what you are trying to do,, portb 0 thru 7 LED's coming on as the voltage rises.??
TRISC = 0x00
ADCON1 = 0x8e
loop:
Adcin 0, an0
If an0 > 125 Then
PORTB.0 = 1
Else
PORTB.0 = 0
Endif
If an0 > 250 Then
PORTB.1 = 1
Else
PORTB.1 = 0
Endif
If an0 > 375 Then
PORTB.2 = 1
Else
PORTB.2 = 0
Endif
If an0 > 500 Then
PORTB.3 = 1
Else
PORTB.3 = 0
Endif
If an0 > 625 Then
PORTB.4 = 1
Else
PORTB.4 = 0
Endif
If an0 > 750 Then
PORTB.5 = 1
Else
PORTB.5 = 0
Endif
If an0 > 825 Then
PORTB.6 = 1
Else
PORTB.6 = 0
Endif
If an0 > 1000 Then
PORTB.7 = 1
Else
PORTB.7 = 0
Endif
Goto loop
End
that one is not voltage
the code above is an analog one
i want you to check it
i cant test it to hardware
what is the code above configuration for ? (PIC)
can you tell me how to generate the conf word ?
