PIC plus-5110 LCD-GPS-BMP280-HMC5983
Since starting this post I have bought this type, so this is what I'm working on at the moment.
C.
hi C,
Moved to correct Thread
E
Hi E, and J,
In my program I have SPI commented out.
On one of the programs, I am following from Chris Holden, even though he used Oshonsoft for writing the program he didn't use SPI in this case as he is moving from Oshonsoft and used 'bit banging' (whatever that is) so that he can migrate to a different system.
See attached program: This works in Oshonsoft, although it is a bit advanced for me at the moment. I would like to simply make a mark on the screen, to get started.
(Eric suggested using ADDRESS 0x01 as a test)
C.
Here's a program with settings as the #64 video. Also a Data analyser reading, showing everything that was recorded.
I also checked the MISO on an oscilloscope, and even though I can't record it easily, I could see a weak reading approx 1/2V, probably what shows on the Analyser.
There were some comments on the other SPI thread, (A program with READ in it) but it was established that there is no MOSI, so does this attached program follow the suggestions.
If the Oshonsoft SPI doesn't work in this way, 'Bit banging' has been suggested also. Is this a good idea?
EDIT:Above I wrote MISO, it should read MOSI.
C.
  • 081017 0830.txt
    081017 0830.txt
The 5110 SPI is Write Only.
The PIC is the Master and the 5110 is the Slave.
Master Out Slave In = MOSI
Master In Slave Out = MISO
So at PIC the MOSI pin has the Data input to the 5110
NOTE: some 5110 do not come with all the resistors fitted.
4 * 10k and 2 * 1k
https://www.amazon.co.uk/LCD-Module...r=8-1&keywords=nokia+5110+lcd#customerReviews
https://www.microchip.com/forums/m148739.aspx
E
EDIT:
You could simplify your program ref SPI5510a.bas
Hi E,
Can you remind me about the simplified method later please, I would have difficulty changing for a while.
Attached shows the digital protocol. Is the MOSI pulled up or down? The analyser appears to show '0' at MOSI. Is it the 2x1K resistors for this? (and which other 1)
EDIT: Just tried the MOSI PIN (at the 5110 input) to check the connection, with a slow ON/OFF it shows ok on the oscilloscope.
C.
I tried a previous program with the longer version of SPI (I substituted the SPI settings) , here's an analyser read out showing MOSI working. ????
C.
EDIT: Channel 2 is connected to the C/D PIN on the module. As it shows the same movement as the MOSI PIN it may be some sort of echo?
Is there's any possibility it could be a problem that I am using 18LF2520 and Oshonsoft only supports 18F2520?
C.
EDIT: Eric, Just tried your program @ #86, again no signs of life!
I'm modifying an old circuit with an 18F2420 which Oshonsoft supports, to see if there's any difference.
hi C,
As you know, I would like to help you solve the SPI problem, but you are making it almost impossible by posting programs which are so over complicated.
If I post a cut down diagnostic Basic SPI program for the 5110 only, will you try it and advise what you see.??
Eric
hi C,
Eric
Hi Eric,
I edited my last post #71 with the results of your cut down program, just as you were posting.
I appreciate your help of course, but I am limited in my skills, and have to print everything out and comment it so I can follow, so big changes take me longer time to digest. Sorry.
C.
hi C,
Program the 18LF2520 with this simple program.
Connect the 5110 to the PIC pins as per the program [ no changes made ] but note that Oshonsoft SDO means MOSI .
The LCD should display all pixels.
The image shows that the correct data is being sent from the PIC when simulated.
E
hi C,
This is my point, it is easier and more effective to solve a projects problems in a separate diagnostic program, rather mixing it into the main program.
Once you have debugged the program fragment and it drives the hardware, then you can start adding comments to that fragment and copy/paste into the main aprt.
E
hi C,
E
Hi E,
Same result, nothing shows.
I'll try again tomorrow and test it with the Analyser, and post the result.
EDIT: I understand that PIC SDO-----------MODULE SDI = MOSI
C.
hi C,
OK,
Post your images of the SPI signals.
I guess you have the backlite, lit on the 5110.?
Any chance of a clear photo image of the PIC to 5110, showing the wiring.
E
I asked just in case his Contrast setting was too low for viewing in ambient light levels, having the back lite On, should just show the pixels, if they are present.
