PIC 16f886 brain F@rt
olly_k
So I have programmed 876's in the past and now using what we have am using this pic to send data to a transparent latch. Now I have configured PORTC as all outputs
but when I come to manipulate PRTC,0 I get no high output. However, in resistance, the meter 'sounds' continuity for every pulse but there is no high output, i.e. switching between hiZ and ground only. PRTC,1,2,3 etc ok
Oh and tried 3 chips, nothing connected to the output either.
I thought I had configured outputs properly, my header is below...
Can anyone help me see wood for trees?
    org 0
    clrf    PORTA
    clrf    PORTB
    clrf    PORTC
;    clrf    PORTD
    clrf    PORTE
    banksel    CM2CON0        ;B2
    clrf    CM1CON0
    clrf    CM2CON0
    banksel    OSCCON        ;B1
    movlw    b'01110000'    ;8Mhz selected
    movwf    OSCCON
    banksel ANSEL        ;B3
    movlw    0x00        ;Set portA to digital I/O
    movwf    ANSEL
    banksel    TRISA        ;B1
    movlw    0xFF
    movwf    TRISA        ; all portC OUTPUTS
    movwf    TRISE
;    movwf    TRISD
    movlw    0x00
    movwf    TRISB
    movwf    TRISC
    banksel    OPTION_REG    ;B1/3
    movlw    b'10000111'    ;use Prescale 256:1     **NOT YET DEFINED**
    movwf    OPTION_REG
    clrf    T1CON
You've only posted a snippet of your code and not the bit that sets the output.
