PBPluse "Warning" problem!?
brodin
When i am compiling my code this text comes upp:
PROGRAM COMPILED OK. 7959 Words used
114 Variables used in the 16F876A from a possible 368
Warning! Code will overwrite bootloader routine at top of program area.
THERE ARE WARNINGS!
What does this mean?
The problem occured when i am adding this line:
Milli = Milli - (Minute * 0.333)
Where Milli is a float and minute is a byte.
But it doesn't seems like there is something wrong with that line. Because when i delete another line it works ok!
Strange, seems like there is a memmory problem. But i havent used all the code space yet! only 7959 of 8000 something!
I believe there may be a memory problem. There is 8k available in the 876 and I think the bootloader takes a part of it leaving less than 8k for user code.
THERE ARE WARNINGS!
Indeed, Seems like your using a bootloader. Wich is normally programmed into the pic near the end of program memory. Bootloaders for 16F devices normally take up something in the range of 256words
Okey, but do i need the bootloader. Do i need that when i am using a ICSP programmer? Or what it is there for?
The compiler obviously knows about the bootloader, or it wouldn't be giving you a warning about it.
A bootloader allows you to program the PIC via a simple serial lead, no programmer needed - except to load the bootloader code in the first place.
You must have a seriously long program to be using that much memory space, 8K of PIC code is a BIG program.
Yes, it is a really big program. It contains a lot of text (LCD data) which takes up a lot of space. And i am using float point routines. The program so far has got about 900 lines.
The circuit has got a 2K EEPROM. I have thougt about putting the text there because i don't use the whole eeprom for other data storage. Or maybe in the internal EEPROM.
So i can skip the BOOTLOADER if i don't use the simple programming?
It doesn't affect any other functions, right?
If you're using a normal, external pic programmer then there is no need for the bootloader. Bootloading is used for self-programming. You'll probabely need to change some settings on your compiler to tell it you won't be using the bootloader.
