I am creating my first PCB layout. I am using a 14 position connector terminal block (Digikey 277-1731-ND). I don't fully understand the datasheet. It mentions a hole diameter of 1.2 mm and a pin dimension of 0.9 mm. Currently, I have noted 2.92 mm round pad with a 1.32 mm hole.
1) What size pad would be best.
2) Using the above pad size only leaves about .635 mm in between pads. Is that too close to solder?
3) What is the minimum suggested width between pads?
