outputing the difference between two flow transducers.
mel8030
I need to determine the flow difference between two flow transducers in a fuel injection system. The transducers output a pulse whose frequency is dependent on flow. First thought is to use two D/A converters, a deference amplifier then a A/D. Is there a better way? Maybe a chip combining most of these functions or a micro and some programing?
A standard D/A won't work since they require a digital word input not a variable pulse frequency.
You could use an up/down counter with separate clock inputs for the up and down such as a CD40193. You could count for a specific period of time (say 1 second) and then read the output, and reset the counter for the next read. This could be readily done with a single microprocessor also.
Alternately you could use two frequency to voltage converters, such as the LM2907/LM2917, and subtract their value with an op amp difference circuit to get the flow difference in volts.
