Hi.. I'm new here. I want to ask about crystal oscillator. I'm making an oscillator using an IC (MM5369), a 17 stage oscillator / divider. At the IC datasheet, the crystal that I should use is 3.579545 Mhz to result a 60 Hz output frequency. But I need only 50 Hz. I'm looking for how to calculate the crystal that I have to use, so the output will be 50 Hz, but all I found is how to calculate the capacitor load at the maximum load so the frequency output of the crystal will at a stable condition.
Can anyone help me how to calculate the crystal that I should to use so the frequency output from the IC MM5369 will be 50 Hz? I want to put down the circuit design from my oscillator, but it's look like I can't put it. If anyone need the circuit design to found out the formulas, please send me an e-mail to boy_andre@yahoo.com, I'll send the design to you.
Thank you for advanced.
Regards
Regards
