oscillator problem
gomathi
sir
i wrote simple led display program for pic16f877
i download hex into pic ic using picall porogrammer.
now i connect to 4MHZ oscillator on 13 and 14 pin of PIC .
22pf capacitor is grounded.
problem is when shake the oscillator only i will get output.
can u find out where problem was?
kinjalgp
Active Member
There is a possibility of dry solder too. On what material/base have you constructed your circuit?
kinjalgp
Active Member
May be the connections are loose on your breadboard. Also breadboard has more noise than vero-boards and PCBs. Have you used decoupling capaciotor (0.1uF) across Vdd-Gnd Pins of your PIC? If not connect it. It reduces considerable amount of noise. Make this as a practice. Always use decoupling capacitor across the power pins of all ICs in your project.
gomathi
sir,thanks for ur reply
i connected 0.1uf across vdd and gnd pin of PIC16f877
instead of 4mhz crystal and 22pf capacitor shall i use 4MHZresonator oscillator.
kinjalgp
Active Member
Yes even that will work. But before changing make sure that the crystal is the one that is causing problem. Otherwise there is no point in changing it.
Also try to build your circuit on a vero board or PCB. It will really help if the problem is related to noise or loose connections.
gomathi
i think problem in program
LIST P=16F877
#include <P16F877.INC>
__CONFIG _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _LVP_ON & _DEBUG_OFF & _CPD_OFF
ORG 0x00
BSF STATUS, RP0 ;bank 1
CLRF TRISB ;make all portB pins output
CLRF TRISC
BCF STATUS, RP0 ;bank 0
MOVLW 0xFF
MOVWF PORTB ;put 0xFF in port B (all pins high)
MOVWF PORTC
END
can u tell me this program is correct or not
and configuration word is correct or not
motion
Try this:
   LIST P=16F877
   __CONFIG _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _CPD_OFF
   ORG 0x00
   CLRF TRISC
AGAIN:
  CLRWDT
  MOVLW 0xFF
  MOVWF PORTC
  goto AGAIN
END
There are a few small problems with your code. First, there is no code beyond the end statement. After executing this code segment, the PIC will proceed execution to whatever may exist beyond the code your programmed. Most likely it will be NOP and eventually the program counter will overflow back to 00h and no problem will be observed. However, you enabled the watchdog timer and without the CLRWDT instruction, the PIC will reset.
I also removed low voltage programming and debug options because they might interfere with execution.
It is likely a hardware problem. Go check with the oscillator pins if there is a signal using an oscilloscope or logic probe.
Exo
Active Member
LIST P=16F877
You configured the pic for a RC oscillator... You'll need to set it to _XT_OSC to work with a crystal
