crusty said:with lots of love and hugs.
Man, I can just 'feel the love' - but what I can't feel is a low frequency variable sinewave!
Well if you wind a really large coil around the garage and put it in parallel with a huge capacitor. If you park the car outside the garage you get 2Hz and if you park inside you'll get 0.2Hz. Simple really.Nigel Goodwin said:No, we all read the requirements- how were you planning making a 0.2Hz to 1.75Hz variable LC oscillator?.
kchriste said:Well if you wind a really large coil around the garage and put it in parallel with a huge capacitor. If you park the car outside the garage you get 2Hz and if you park inside you'll get 0.2Hz. Simple really.![]()
audioguru said:JFETSs are used for automatic-gain-control in sine-wave oscillators and in audio equipment.
A JFET produces about 0.1% distortion when the signal across it is more than about 30mV RMS. If the signal is 300mV then the distortion is severe.
Adding a signal to the gate that is half the level of the signal at the drain reduces 2nd harmonic distortion a lot.
Years ago the "chorus pedals" used bucket-brigade echo/delay ICs that had 2.5% distortion.
I understand that you will use matched JFETs in all-pass filters as part of a phaser effect circuit. I think the old CA3080, LM13600 and LM13700 transconductance amp ICs were used in the 70's to do it.
Google is full of old flanger/phaser circuits.
audioguru said:A switched-capacitor Butterworth lowpass filter IC does wonders to remove harmonics. A square-wave can be filtered with an 8th-order IC and the results are low distortion sine-wave.
My very low distortion sine-wave generator uses a CD4018 to make a stepped sine-wave with 10 steps (10 times over-sampled) then is filtered by an 8th-order Butterworth filter IC. The distortion is 0.01%.
OMFG u won the internetz!kchriste said:Well if you wind a really large coil around the garage and put it in parallel with a huge capacitor. If you park the car outside the garage you get 2Hz and if you park inside you'll get 0.2Hz. Simple really.![]()
Hero999 said:Wow your motor, idea sounds expensive, power hungry and unreliable, I don't know how you got all three in one!
Hero999 said:Filter any waveform with a 50% duty cycle enough and you'll get a sinewave. Build a 7555 timer circuit with 50% duty cycle, add a non-inverting buffer to the capacitor, stick a picky enough filter on the end and you'll have a near as damn it perfect sinewave.
audioguru said:Five 1st-order filters in series make a very droopy filter that begins attenuating frequencies far below what is wanted.
A Butterworth filter uses positive feedback to boost the response so it is flat right up to the cutoff frequency.
But the filter needs to be tuned so that it still greatly attenuates the 3rd harmonic of 0.2Hz (0.6Hz) and allows a flat response at 1.75Hz.
A switched capacitor Butterworth lowpass filter IC has its 8th-order cutoff frequency changed with a single resistor on its built-in high frequency oscillator.
SeanHatch said:Hmm I did not know anything about the minimum load of 2Kohms. I will have to fix things, then.
I tried that phase shift oscillator schematic you showed me a while ago, and I couldn't get it to work. It'd be nice if I could, though.
I've simulated the oscillator I have now in SPICE, using the uA741 subckt model I copied from my textbook. The results are pretty good (post filter), ill post some images tomorrrow. But, could the model be missing something that would mislead me?
Right now the output of the oscillator filter swings between -0.5 V and -2 V, which shouldn't short the FET, but is a pretty big sweep in regards to distortion; i think you told me this earlier.
do they make triple pot kind of things? i've never seen them.
