Optics Question
neptune
hello people,
I want to know that if i want to split a beam of light into half of the luminosity then how do i do it.
i can either place a half polished mirror to split it into 2
or
i can place a thin wall parallel to beam to cut it into 2
in either case if 1 lumen of beam is visible then can i split it into two .5 lumen's beam ?
which would be the best method ?
If you have to retain the cross-sectional shape of the beam then I don't see how the thin-wall method would work. If the split beam shape is not important the thin-wall method may be simpler. Depends too on the intended beam directions after the split? Either method will be lossy, so you won't get exactly 2 x 0.5 lumens from 1 lumen.
i want equal light not exactly 0.5 but 50:50 and shape doesnt matter here
