Op amp power
sfink06
Probably a couple of hundred, but why would you want to? What is it that you are trying to do?
I am running some DC to HV-DC converters with these amplifiers, which take input voltage from a DAQ. someone mentioned that the power supply was limited to 5A, and that I should make sure that it would be able to run all 9 op-amps in the circuit at the same time. I don't know how many amps they need to draw from the power supply.
Well, now that I look a bit closer at the datasheet, I finally see the right figure.
Maximum continuous current output. +/- 3A.
So less than two running at full output current.
These are big ones. :)
for my application the the converters draw about 1.5 amps, but I was hoping that on page 3 under power supply the listing of max Q current being +/- 20 mA would mean that I could run all nine. I wouldn't know how to even start dealing with the headache of switching between amps the whole time.
The Q current is the current that is being drawn when it is not in use, but still powered. It's the minimum current that it will draw at any time.
Looks like you may need a bigger power supply.
