Odd double digit display
thatdecade
7 Segment Double Digit Blue 1.0 Inch (25.4mm) LED Display Specs, Data Sheet LCD-10022TB11 from lc-led.com
I bought a few of these 2 digit 7 segment displays and after wiring one up, I am not sure what purpose the manufacturer intended.
Take a close look at the circuit drawing on that page. 10 pins. 1 common pin for each side. The rest of the pins, abcedfg, are shared between the sides. If I power both common pins and light up segment A, segment A for both digits will illuminate.
I had intended using it for a timer/counter. That is out, so now I am trying to think of a good use of this strange display.
You use a microcontroller to multiplex the display. For example, if RA0 and RA1 are linked to transistors on the common pins and RB0 to RB7 are connected to the 7-seg pins, you could do something like this:
int HexDisplay[] = { ... } // insert values for displaying 0 -> 9
int countA = 0;
int countB = 0;
while(true) {
    clear(RA1);
    set(RA0);
    RB = HexDisplay[countA];
    clear(RA0);
    set(RA1);
    RB = HexDisplay[countB];
    // check WDT here and increment countA/countB appropriately
When you multiplex them with a PIC you're only actually lighting one LED at a time. Since the switching is extremely fast (I'd guess ~1MHz on a 4MHz clock) you can't tell that they're flickering on and off. You're not likely to be consuming more than 70mA for the LEDs and PIC when multiplexing.
70mA... hmm I may have to sacrifice an IC to test out a theory. If I ditched the transistors and connected the two common pins directly to the IC, that would mean at most there would be a 35mA load. My IC can support max loads of 40mA per pin.
Reducing the components is worth a $2 risk on the prototype. ha~!
You should be ok, but 70mA was a ballpark figure so don't be dissapointed if it does kill the chip. It could be more, it could be less.
