Object following Robot
Boajunta
Hi
I need to build an object following robot using two 5-10v dc motors. I have purchased the chassis and fitted thedc motors onto it. They are meant to run individually.
2 IR leds(part number-ZD1945), 2 IR phototransistors (part number- ZD1950) are to be used with NPN transistor(part number- 2n2222a) are to be used with E-series resistors.
The left front sensor is meant to turn the right motor towards the object when detected and vice versa fortge left front sensor.
When the motors are turned on they should move in the forward direction.
I need help with designing this circuit and want to know what value resistors are to be used to get the motors in motion.
Kindly help with the circuit design
Cheers
