bibaRestro said:
SS, keep in mind the spoiler switch on the dash in the SRT6 is just a dummy. A couple of things: What is the chime situation? Is it supposed to be a warning chime like a backing up one? I'm quite sure there is no chime for the spoiler;
https://srt-6.com/pdf/tsb/SB_23_040_04_Spoiler.pdf
Quote from above:
OPERATION
The rear spoiler is powered by an electric motor
located directly below the spoiler wing in the spoiler
assembly. When the vehicle reaches 62 MPH (102
km/h), the rear spoiler deploys, giving the vehicle 40
Lbs. (356 Newtons) of downforce at 80 MPH (129
km/h). As the vehicle decelerates, the rear spoiler
starts to retract at a speed of 39 MPH (62 km/h). When
retracted, the spoiler nestles between the rear quarter
panels and the
ZH
_______________________________________________________
REAR SPOILER
2328108 - 3
The spoiler can be manually deployed at lower speed
using the override switch mounted in the center
console. Pushing the switch up raises the rear spoiler.
Pushing the switch down lowers the rear spoiler.
To prevent injury, the rear spoiler retracts in defined
steps to allow time to pull any hands or foreign objects
that may be in the path of the rear spoiler before it is all
the way down. If the rear spoiler gets disturbed while
retracting automatically or while retracting manually,
the rear spoiler is automatically driven up again and will
lock in the up position. During manual retraction, if you
let up on the switch, the rear spoiler will be driven to its
up position.
When retracting the rear spoiler manually,
a single audible chime is produced to indicate to the
driver that the rear spoiler is in the fully retracted
position. A warning signal (LED) on the spoiler override
switch illuminates, indicating a malfunction to the driver.
A malfunction that prevents the spoiler from deploying
illuminates a red warning lamp in the override switch.
rear liftgate window.
End Quote.
PS. I saw a Crossfire in the other lane a day ago. I saw a Lamborgini about a mile from the house this summer. I've seen one other sighting in the state. Vipers and DeLorean's are rare too.
