Oznog said:BASIC is just too primitive for me... C is more logical to code in and so much more effective.
bluex_scf said:my basic compiler support Function and Porcedures creation/call, and Type définition (Structures), and Unions(for BitFields)
so the benefits of a good compiler are hier
- Code reusability (proce and funct with params)
- Easy Language to learn
- and it will be FREEEEEEEEEEEEEEEEEEEEEEE with all the SOURCES CODES OF THE COMPILER .... GPLLLLLLLLLLLLLLLLLLLLLL
so i do not know why your C compiler is more logical than Basic ?
bluex_scf said:the compiler is entirely writen in Ansi C language using Lex and Yacc tools. Actually i'm correcting some issues with pic12Cxx series. It seems to work correctly with pic16Fxx and 18Fxx series. I have not finished yet debugging. The ASM code generator is almost finished and there's still somethings to improve with the code translator/optimizer since i generate a PseudoCode witch is converted to MpasmCode. The code converter/optimizer will be rewriten for 85Cxx séries and Atmel Series. I think that it will be the first open source Basic Cross compiler since i have not found anyone on the market . I think that i'll have finisshed the first release in the end of June or the mid-July !!! it depends on my free time since i'm writing it as a hacker every afternoon after work please .. be patient. Nigel perhaps i'll contact you soon for Beta Tests
thanks
bluex_scf said::idea:
Hi every body !
I'm working on a new, FREE and simple Basic Language Compiler for Microchip PIC12xx PIC16xx and PIC18xx !!!
Actually my compiler is Fully Syntax compatible with MPLabs Pic Pro Compiler, and with Basic STAMP Syntax.
I would like to know what are the enhancements and the useful things you have ever like (or dreamed of :wink: ) in a basic compiler for PIC.
Actually my compiler is generating PURE pseudo Code for an arbitrary CPU, and in a second pass a code generator and an optimizer generate the NATIVE PURE asm sources for the microchip Assembler MPASM.
The port of my optimizer and souce code generator to other cpus like 8051 series is not so difficult and i think that we can have a fully source code compatible between different MCU's (the architecture dependent features will not be compatibles of couse).
I need your opinions and ideas to enhance my compiler !!!
the estimate date is JULY 2004 for the first release (Beta 0.0.1a).
It will be FreeWare under GPL licence. Source codes will be Free (open source) from the release of vers 0.8 or 0.9 in order to avoid an anarchic evolution of the project or its derivative if wany.
help :::
ivancho said:I guess some time I would like to be able to compare strings. PIC BASIC PRO can't, so it would be a good think to have.
