Notepad ++ source editor
Mosaic
Hi all:
I updated the Notepad ++ language & styler files to handle 16F asm code. Much more readable than Proteus/oshonsoft/ MPLAB.
The commands are grouped & color coded to make logical branching and PC control (eg. goto) easy to spot.
I'll add 18F soon.
Rename the file extensions to .xml and overwrite the files in the C:\Documents and Settings\Application Data\Notepad ++ folder.
Application Data is a hidden folder.
Select the Assembly option in the Languages menu item.
  • langs.txt
  • stylers.txt
What good is the color if you're still ignoring any kind of tab/column formatting. That example looks just as bad as any other code you've posted (sorry, but it's true)...
