Hi N,Try using an external (USB) sound 'card' instead of the internal one.
The sound card isn't dedicated to one app... When you run windows media player you will have "other" sounds amplified..Hi N,
Ok, i'll look for one.
Why doesn't my two month old internal one work as inspected?
C.
Hi C,What computer do you have?
My HP desktop internal sound card has absolutely no noise and it goes to a good amp that drives a pair of high quality speakers.
Sounds like maybe something's faulty with yours.
Hi D,Are you plugging into the front jack or rear jack? I've never seen a computer where you can use the front jack because they pick up so much noise somehow.
And the rear?Hi D,
Front side also in the screen. All make noise.
C.
Hi D,And the rear?
Well, if it's happening in your rear jack too then there's not much you can do. Either changing your the soundcard, mobo, speakers, or cable lengths. Or go with an external amp. Just a bad combination of equipment.Hi D,
Sorry my mistake. My computer only has connections at the side, rear and the screen.
C.
Hi M,I was going to suggest a transformer ground-loop isolator in the audio path. We hams who connect audio to/from PC sound-cards to our transceivers found out twenty years ago that the chassis of the PC (the gnd side of the RCA jack) is hot with common-mode PC related garbage, including crap from the switching power supply in the PC. The ground-loop isolator effectively breaks the path for the common-mode noise that would otherwise travel along the shield of the audio cable.
No clue.Hi M,
That's fine, but can you give any explanation, as to why even with the GLI removed the noises are now not there?
A GLI is a marketing term. Inside is a transformer with isolated windings. It takes two independent transformers to pass stereo.Do you know what the difference is between a GLI and an isolating transformer?
C.
Hi M,No clue.
