Network Relay
Suraj143
Active Member
I have couple of buttons (5 or 6), needs to connect them to nearby LAN port (Network port).& all the CAT5E cables from these buttons coming to a network switch.Want to decode them & make some relays ON.Is there any way of doing them without going deeper?No need IP address level, is there any way of sending data & decoding over LAN?
I wouldn't have thought so - you need a network connection and a processor - there are countless Arduino examples, and various PIC ones as well - if you don't have an IP address how do expect to access one particular device?.
Obviously a FAR easier method would be to use WiFi, a simple ESP8266, couple of relays and drivers, job done - and again there's endless examples of that on the net.
I started out running CAT5 all over the house but now I am using WiFi. Nice to not run wires.
The EPS8266 is good but I am not good at programming so I looked for a product that just works with out programming.
There are other companies with product.
The Sonoff products have 1 to 4 relays. Work WiFi or 433mhz. Some have buttons. All work with a phone and PC.
The TH10 & TH16 have the option to measure temperature and make decisions based on time and temperature.
The Sonoff one does use an ESP8266, and there are various examples of how to reprogram it on the net to make it local control only (as supplied it works via a server, presumably in China, and I had a great deal of trouble registering mine on it - but managed it eventually). It's currently controlling a bedroom table light via Alexa :D
As for 'not very good at programming' - you simply download the source code from the examples on-line, add your own WiFi details (as per the instructions) and reprogram the device (again, as per the instructions). So not really any 'programming' required.
I don't want to take over this topic but I think it is related.
Sonoff and others have buttons in a "remote" looking box. Battery powered.
I am looking at "switch plate buttons" that look like a normal wall switch. The Sonoff ones are only good for 2 or 3A. My idea is not connect them to a light but just leave them sending the on or off command on the network. Then have 15A relays switch to respond to the commands.
Picture of 8 buttons.
4 buttons.
Switch plate.
Wife likes the look of switch plates compared to my usual switches and wires hanging out of a hole in the wall. lol
